Canon T8i / 850D self-timer lamp... disable?
Len Philpot
Len Philpot Contributing Member • Posts: 625
Yeah, I've only had this camera for nearly two years now but either I never noticed before or the self-timer lamp has just started flashing ...and I'd like to disable that. I never use the self timer for self portraits, but I use it regularly for landscapes to reduce vibration. I don't recall it flashing before but maybe I've just been blind.
Is it possible to disable the lamp when using the self-timer? I've Googled & looked through the manual to no avail.
I guess a spot of gaffer's tape could be a last resort, since per the manual it's the "Red-eye removal / Self-timer lamp", neither of which is a factor if affected.
Thanks.
Len Philpot
Retirement: 4th best thing to happen to me
https://www.instagram.com/lphilpot01/
https://flic.kr/ps/doiTr
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
Dunlin Senior Member • Posts: 2,611
Re: Canon T8i / 850D self-timer lamp... disable?
I've never heard of it being possible, and I don't think it's on the 3 Canon DSLRs I've owned/own (1200d, 600d, 7d).
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
stevet1 Senior Member • Posts: 1,300
Thanks.
Len,
It's possible that you never noticed it before because you were taking landscape photos in the daylight.
The manual says that the lamp does not flash when the screen is facing is facing backward towards the shooter in taking self-portraits.
The manual doesn't say anything about disabling it like you can disable the beep.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Len Philpot
OP Len Philpot Contributing Member • Posts: 625
Thanks.
Len,
Steve Thomas
Yeah that's all I found, too. Apparently I just never noticed it before.
Thanks.
Len Philpot
Len Philpot
Thanks. Probably not possible.
Len Philpot
