Re: Cheap underwater depth and temperature sensor
andrewins wrote:
Hello,
Do you know if one can buy cheap underwater depth and temperature sensor that can store the maximum depth and minimum temperature data?
It will be good to attach such device to my underwater Gopro tripod that I place on the bottom of the rivers via rope while taking videos of fishes.
How deep are you lowering this to, and how long are you running it for? The dive computers could suffice until you exceed the deco limit for the depth. So if you dropped it past 100, that becomes a problem. Some have gauge mode which just reports time and depth, and maybe temp.
The cheap and dirty answer is you find a computer that stores temp at bottom as part of its dive log. Attach it to your rig and when you pull it up, run the gopro a few more seconds as you open the log data. This would presume that the coldest temp matches the deepest depth, which is usually, but not always true.
More convoluted is to mount it on the edge of the gopros view so you could see the figures live. It would cost you some of your display, and could get bumped out of the way, in which case you fall back to approach one. Finding a computer with bigger digits would be key....and you might have trouble with the gopro's min focus distance.
Now if you're willing to spend, the Paralenz dive oriented video cam will superimpose the depth and temp on the recording.
https://www.paralenz.com/vaquita
Your dive, your overlay
Add a little extra to your recordings with up to two custom, real-time Dive Overlays: depth, temperature, dive time, ascent/descent rates, and date.
This model uses the depth sensor to do color correction.
The gotcha - this sells for $799. And it's cylindrical shape is not nearly so easy to bolt onto other objects. GoPro put a lot of effort into this area to make it approachable for all of the Red Bull types.
