X-S10 sensor damage assesment
Started 6 months ago | Questions
Tom45
Tom45 Forum Member • Posts: 67
So I did the wet clean of the sensor with the appropriate equipment and "by the book" but one thing I didn't do is doing it gently. While swiping the sensor left to right with the swab I probably was pressing a bit to eager and pulled the sensor in the swab direction for a brief moment.
There was "turn off the camera" type of warning on the back, with the red ! icon, turned off and on the camera, stabilization seems to be working, as far as I can tell it's working as usual.
But just to be sure...could I've damaged the IBIS - or to make straightforward question - is it possible to damage the IBIS and have the camera working, without the IBIS? Or is it simply - camera works all is ok, damaged IBIS camera won't let you operate.
Let me know please I'm anxious
Squaring the circles
 Tom45's gear list:Tom45's gear list
Fujifilm X-S10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II Sigma 56mm F1.4 DC DN | C (X-mount)
Flying Fijian Senior Member • Posts: 1,623
Re: X-S10 sensor damage assesment
If everything's still working fine then I wouldn't worry. If there's any issue you will find out soon enough lol.
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
a_c_skinner Forum Pro • Posts: 13,047
I think it is very unlikely you've damaged it.  It is a warning though about cleaning cameras, you should only do it when the images show it is needed as there is always a bit of risk, if only risk of worry.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
craigwell47 Senior Member • Posts: 1,197
Surely the camera should be turned-off before wiping the sensor? The sensor movement as described when cleaning alerted the camera the IBIS unit moving not as instructed by the camera. On some cameras IBIS unit activation audible; by listening next to your ear.
GMacF Contributing Member • Posts: 999
Not for Fuji IBIS cameras (I’m not sure on other brands). The camera needs to be on with IBIS activated to hold the sensor in place while cleaning.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
Nielk Mike Senior Member • Posts: 1,480
Same with Sony: Cleaning function locks the sensor in place.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Don't forget the shutter must be open. This is not the case when a camera is switched off.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
