E-Shutter readout speed/rolling shutter
nnowak Veteran Member • Posts: 9,082
5
I am having trouble finding accurate data for the still image electronic shutter readout speeds.  I know the X-H2S is the fastest of the bunch, but I am seeing conflicting numbers that potentially show that the X-T3 is faster than the X-H2.  Also, much of the data I am finding is for specific video modes, which is not too useful as it is highly dependent on bit rate, frame rate, and resolution.
Has anyone here done the testing, or can point me to accurate numbers for still image full sensor readout speeds, specifically for the X-T3/X-T4, X-H2 and X-H2S?
I currently use the X-T3 and am not sure I want to go all of the way to the X-H2S.  I would prefer the X-T5, but not if the readout speed will be slower.
Oh how I wish this data was part of the standard DPReview spec' sheet.
Fujifilm X-H2 Fujifilm X-H2S Fujifilm X-T3 Fujifilm X-T4
Lukedriftwood Regular Member • Posts: 235
Re: E-Shutter readout speed/rolling shutter
X-T3/X-T4: 1/40s
X-H2: 1/40s
X-H2s: 1/80s
boogisha
boogisha Senior Member • Posts: 2,858
Lukedriftwood wrote:
X-T3/X-T4: 1/40s
X-H2: 1/40s
X-H2s: 1/80s
If I`m reading this correctly, it should mean X-H2 (with its 40 MP) is on the same level _frame-wise_ (reading the whole sensor) as X-T3/X-T4 (with their 26 MP)...?
If so, that should also mean X-H2 is reading each single sensor line faster than X-T3/X-T4 (as it has more lines to read, due to higher resolution, yet still does it in the same time-frame), but in general, overall performance should be pretty much similar (not to say the same)?
Would that make the rolling shutter pretty much on-par, too, or higher resolution makes a difference (for better or worse)?
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
OP nnowak Veteran Member • Posts: 9,082
X-T3/X-T4: 1/40s
X-H2: 1/40s
X-H2s: 1/80s
Thus my confusion.  I see Fuji touting 1/180 for the X-H2S, but I think that may be for video.  I have also come across 1/60 for the X-T3/X-T4 and 1/30 for the X-H2.
baobob
baobob Forum Pro • Posts: 18,248
I sold the XT3 and got a XH2s. I have posted in the forum sevral series of BIF shots all in ES without any visible rolling shutter effect. The readout of the sensor seems fast enough to avoid that in many shooting situations.
I mainly shoot now in ES without specific issue. No numeric data about reading speed however, but certainly a big difference ref XT3
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Alan Hewitt Photo
Alan Hewitt Photo Contributing Member • Posts: 909
I'm about as technical as a old bit of wood so there's a good chance I'm wrong on this! But... I would imagine some machine or software that is capable of accurately timing electronic shutters charge and read out like this to thousandth of a second would be so incredibly niche and specialist it's probably out of reach of review sites, even the mighty DPReview!
FUJIFILM UK Ambassador/ X-Photographer
Formatt-Hitech Ambassador
Wildlife Photographer, filmmaker, photo safari & workshop guide, freelance writer.
INSTA1: alanhewittphoto
INSTA2: bts_alanhewittphoto
 Alan Hewitt Photo's gear list:Alan Hewitt Photo's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8 +2 more
There is no need for anything that complicated.  One of the simplest methods uses standard household LED lights.  Some (many?) of these lights will flicker at a rate that is double the mains frequency.  If you use E-shutter to photograph a light colored wall illuminated by one of these flickering LEDs, your photograph will have regularly alternating light and dark bands.  If you know the flicker frequency of the LEDs and count the number of bands, it is simple math to calculate the readout speed.  This method won't give you an answer down to the last decimal place, but it will easily distinguish between 1/30 and 1/60.
Dem Bell Senior Member • Posts: 1,091
It is much more accurate to measure the distance between bands in pixels, N. If you are in Europe, this distance corresponds to 10ms. If you divide image height H by N, then multiply the result by 10, you'll get the sensor readout time in ms.
Should be able to get within 1%.
Alan Hewitt Photo
Thanks! I had an inkling there would be a more practical method.
catastrophe Regular Member • Posts: 166
H2s 1/160 x-t4 1/40 h2 1/28
https://www.youtube.com/watch?v=oqT-FKiyKso
boogisha
Hmm, interesting, quite a comprehensive list of cameras he has there... Does he say what his sources are? Or he measures/calculates it himself?
Here`s the exact moment where the table is shown:
https://youtu.be/oqT-FKiyKso?t=361
If those numbers are true, it would basically mean the sensor readout _per line_ (or per pixel, if that even makes sense) is pretty much the same between X-T4 and X-H2, but then higher MP (thus more lines/pixels) causes X-H2 sensor to be read slower in general (whole sensor)...?
7rvar Regular Member • Posts: 377
I'm curious what X-Trans 3 figure is (X-T2, X-H1, etc.)
I'm comfortable with electronic shutter performance from those cameras in many situations but would hesitate to use anything slower.
 7rvar's gear list:7rvar's gear list
Fujifilm X30 Canon EOS 5D Sony a7S Fujifilm X-H1 Fujifilm X-E4
from memory 1/25 s. You've got the X-H1 listed in your gear, you can measure it.
Kaoticphoto Regular Member • Posts: 379
looking at the review 6K video from XH2 has a rollign shutter really similar to XT3/4, so yes speed by row seem similar between these sensor.
Xh2S is around 4X/5X faster
Hmm. Some of those numbers contradict those posted above by Lukedriftwood.  Another curiosity is the Nikon Z9 is listed as 1/270 in that video, and I could have sworn Nikon explicitly stated it was 1/200.
I thank you for sharing the methodology, and while it pains me to say, I just want someone to spoon feed me the info. I would have to write a blog about it or something to justify testing myself.
Searching has suggested
X-Trans II ~1/15s
X-Trans III ~1/30s
I have cameras from all but the latest (X-H2 & X-H2s generations) so perhaps I will test it out sometime. Really an intriguing figure for X-H2s though.
boogisha
Yeah, seeming informed, I`m also interested in what Lukedriftwood has to say (if anything, besides the numbers he shared already).
I believe that the data in the list comes from somewhere else but I don't know where. He does a lot of reviews and training on Fuji, Canon and Sony. I have never seen anything from him on Nikon, OM or Lieca.
I may be wrong but having watched many of his videos over the last few years, I am reasonably confident that the list is correct
