Critique and question
Started 5 months ago | Photos
phazelag
phazelag Veteran Member • Posts: 3,376
I totally don't mind critiques.   Critiques have been super helpful over the years.
All taken with M50 with with Loawa 9mm F2.8 Zero D.  Which does not register in Exif .   Set to F11 and infinity focus.
First photo was my favorite, second photo the Zero D shows quite of bit of D in the lower left airplane.    The 3rd photo is for reference to see the plane straight and undistorted.
I did download and apply the Venus Optics Lens profile but that only seemed to correct minimal vignetting and some aberrations but does not seem to correct distortion.   Might not be possible as manual distortion correction didn't really help.   Its not a huge deal, this lens is great and rarely has this issue, but I would like to know what caused this.   Was it my angle to the plane and just have to live with it?   Can it be corrected?   Also the photo was cropped so it not even in the far corners.
I would like to know if the first photo is appealing or is the plane just too far away to make a good subject?  Kind of reminds me Icarus! And the lady is very happy looking.
I also notice DPReview can not present photos great in full screen mode on occasion.   Let me know if these look clear when you see them.
Thanks in Advance.
 phazelag's gear list:phazelag's gear list
Sony RX100 III Canon G9 X II Ricoh GR III Sony RX100 VII Canon EOS M50 +10 more
Comment & critique:
Canon EOS M50 (EOS Kiss M)
phazelag
OP phazelag Veteran Member • Posts: 3,376
Original Uncropped distorted image
User1303423862 Senior Member • Posts: 1,070
Re: Critique and question
They look fine on my monitor, nicely exposed, good photos. Others will have more knowledge on rectifying the distortion than me.
I think my approach would have been to take a zoom lens to an airshow. For 'setting the scene' I'd have orientated to portrait at wide angle and taken a series of shots to stitch together using software later. That would have dealt (pretty much) with distortion issues.
Then I'd have been able to zoom in for the 'Icarus' shot to get more resolution. I could have used the tele end of the zoom to get more detailed shots of individual planes too.
The main thing is that you enjoyed the event, and got some memorable captures with your super-wide lens.
I am not a number. I am a free man.
How the heck did I end up with this username?
 User1303423862's gear list:User1303423862's gear list
Canon EOS R Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 28mm F3.5 Macro IS STM Canon 70-300 F4-5.6 IS II +4 more
JustUs7 Senior Member • Posts: 4,327
I take Zero D to mean vertical lines will be vertical (not bowed).  But not all wide angle distortion can be prevented.  Things close to the camera and at the edges of the frame will be stretched when using ultra wide lenses.  Corrections don’t fix this.  Anything that you don’t want distorted, try to keep toward the middle of the frame.
To aid in keeping vertical lines perpendicular (vs converging) turn your level on in the EVF and keep the camera level and with no tilt.  So the green line appears all the way across the level.  Not just at the sides.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
phazelag
Thank you for your feedback!
I also had the 11-22 with me and I took most of the shots with an R7 and RF100-400.  The M50 was mainly to get another perspectives.  So I was thinking like you would have.
phazelag
Thank you.   Thats helpful.
Haha! OK. I'd have taken my M6 and EF-S 50-250 IS + Rexley special 2X TC for an 800mm (equivalent) reach, so I could see which brand of cigarettes the pilots were smoking.
Jayson A Forum Member • Posts: 84
Aren’t you worried about burning your sensor by pointing it at the direct sun light that?
phazelag
Sun Damage.
It’s a good question.    But my answer is not really.    I have looked this up and it’s for sure a risk, but I generally only have it pointed that way a few seconds at a time.  I have done it for years with many cameras with no damage.
I am careful to make these brief but I acknowledge it could cause damage
Re: Sun Damage.
Mirrorless cameras are very different from DSLRs in the way that the sensor is always exposed to light, whereas DSLRs have a mirror in front that flips up for only a split second while the light hits the sensor.
