X-H2s EVF lag
NischP New Member • Posts: 6
X-H2s EVF lag
Hi Fuji crew,
recently purchased this awesome camera. I noticed when I am focusing quickly between subjects/objects there is a very brief freeze before snapping focus to the desired object. It's enough that it's a bit annoying if say I am switching quickly between objects or trying to manually focus on a quickly moving object - a bird hopping about.
I am however using a fringer adapter on an 18-35mm so I would like to know if this is an isolated issue with just my camera/setup or if other people get the same issue.
Thanks all!
FuzzyDice Contributing Member • Posts: 671
Re: X-H2s EVF lag
NischP wrote:
Hi Fuji crew,
Thanks all!
Okay, first are you using Electronic Shutter?  That’s the only way to get blackout free.
Now as for the lag, I would use a native lens as there’s no guarantee a Fringer adapted lens is going to focus as well.
 FuzzyDice's gear list:FuzzyDice's gear list
Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Nikkor AF-S 300mm f/4E PF ED VR Fujifilm 16-55mm F2.8R LM WR +3 more
Flying Fijian Senior Member • Posts: 1,623
Re: X-H2s EVF lag
Have you tried turning on boost mode & evf frame rate priority?
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
OP NischP New Member • Posts: 6
Re: X-H2s EVF lag
FuzzyDice wrote:
NischP wrote:
Hi Fuji crew,
Thanks all!
Thanks, Fuzzy I was using MS but changing to ES did not fix it. I don't have access yet to a native lens but that would be the next logical step if others did not experience this. I would describe it as almost a stutter, it's very very brief and happens when the box goes green, there's less than a half-second of lag before the focus changes. Maybe this is normal and I am not used to it.
Re: X-H2s EVF lag
I did try those thanks, but unfortunately, the same thing. It's very very brief and less than a half-second of lag before the focus changes.
Morris0
Morris0 Forum Pro • Posts: 32,181
Re: X-H2s EVF lag
FuzzyDice wrote:
NischP wrote:
Hi Fuji crew,
Thanks all!
It is about the lens.  The Fringer adapters with a fast lens will preform as fast as the fastest Fuji lenses.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Morris0
Re: X-H2s EVF lag
I suspect you lens is slow or not on the Fringer support list.  AF with a fast lens on the Fringer adapter is near instant.
Morris
