Canon R5C smudge blurry photos?
k327 New Member • Posts: 4
Hi Forum,
I got an R5c as a gift and tried it out in the weekend.
Im totally in love with the movie quality BUT the photo quality is something that im really unsure about since it comes out smudgy and blurry almost everytime i shoot.
I really think this is more about my skills since i am a beginner when it comes to photography.
Photo info:
R5C with EF100-400mm f/4,5-5,6L IS II USM
5464x8192 CR3
ISO 1600
f / 5,6
1/50
The photo is unedited.
What am i doing wrong?
Canon EOS R5 C
Mako2011
MOD Mako2011 Forum Pro • Posts: 28,706
400mm
k327 wrote:
Hi Forum,
I
The image is shot at 400mm with a shutter speed of 1/50s.  Unless you are on a rock steady tripod the camera shake will make the image blurry....even if on a really good tripod...at 1/50s the animals need to be not moving at all (statue still) or you get motion blur.  Given the shutter speed and focal length...not to bad a shot.  Could be improved some in post processing
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
Karl_Guttag Senior Member • Posts: 1,883
Re: 400mm
Mako2011 wrote:
k327 wrote:
Hi Forum,
I
At least, in theory, the EF100-400's IS of 4-stops (16x) should have been good enough to not need a tripod. It probably is on the edge as the IS stops ratings are somewhat exaggerated plus the 1/f.l. the rule should probably be 1/(2 x f.l.). Unless the person used very good and steady technique, camera shake is probably a contributing factor. Also, a good point about even relatively stationary live subjects will move a bit at 1/50th.
On top of the motion blur issues in this specific case, the focus looks like it is short/in front of the deer. If you look at the back fence, you can see that it is relatively sharp on the left and blurry on the right, and the fence is diagonally toward the camera on the left side.
The next question is why is the focus short? It could be that they didn't have the focus locked on the subject. I don't know what focus mode was used. The image is dark which will make AF with a mirrorless camera much more difficult/unreliable. It looked to me too dark (in the image) for eye detection AF to work.
Another issue is the depth of focus at f5.6 at 400mm and that focus distance. I have not worked the numbers, but since the deers are on a diagonal relative to the camera, I would not expect all the deer to be in focus. Still, it should have been enough for the front deer IF the focus was locked correctly, as the shot is not that tight.
There is also the chance that the lens is focusing short. I recently noticed an issue with my old EF 100-400 mk.1 (I have not confirmed it yet), and another person (https://www.dpreview.com/forums/post/66530666) has commented on having similar short focusing issues with their EF 100-400 IS mk.2
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
Mako2011
true
Karl_Guttag wrote:
Mako2011 wrote:
k327 wrote:
Hi Forum,
I
4 stops is only in the in the best of conditions. Looking at the fence...camera shake is obvious. But you are right...it can be done well even at 1/50s with IS and really good holding technique. Here I think the OP was just outside the window. That said...I think it OK for the conditions.  Wonder what he'd have got at ISO 3200
That's also part of the issue (focus parameters) but I was only looking at areas close to the plane of focus regards motion blur/camera shake. May need some more examples to see how things look in better shooting conditions
Ali Senior Member • Posts: 1,969
Re: Canon R5C smudge blurry photos?
Dark conditions, 1/50s, small depth of field, and as Karl_Guttag pointed out possible misfocus could have all contributed to the issue. It’s a challenging scene and setup.
You can probably up the ISO to 3200 or more in cases like this. That in turn would let you up the shutter speed and/or the f stop (as a way to increase depth of field).
Also you may want to shoot some in better conditions first to get familiar with the camera for photos, and to determine that the camera is capable of sharp pictures. (But I realize the deer probably won’t be there for that!)
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
Martin_99 Veteran Member • Posts: 4,631
k327 wrote:
Hi Forum,
Photo info:
5464x8192 CR3
ISO 1600
f / 5,6
1/50
- starting with photography in difficult lighting situation, slow long lens make it worse
- too slow shutter speed (left from your video setting?), I would set at least 1/125s and expect some blurry photos due to movement anyway
 Martin_99's gear list:Martin_99's gear list
Sony a6400 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sigma 56mm F1.4 DC DN | C (X-mount) Sony E 70-350mm F4.5-6.3 G OSS Tamron 150-500mm F5-6.7 Di III VC VXD +1 more
OP k327 New Member • Posts: 4
Re: 400mm
Mako2011 wrote:
k327 wrote:
Hi Forum,
I
The picture was taken handheld. Realizing now after all your answers that at that shutterspeed it shoulve been taken on a tripod!
Martin_99 wrote:
k327 wrote:
Hi Forum,
Photo info:
5464x8192 CR3
ISO 1600
f / 5,6
1/50
Yes its probably from me being used to video settings
Tried a higher shutterspeed recently and it got so much better!
Thank you all for your answers, it really helped me out!
This picture was taken for fun and just to get the hang of the camera with some video settings in mind when it comes to shutterspeed and ISO.
I recently took som shots with higher shutterspeed and ISO which came out so much better
Realize i still have alot to learn when it comes to photography, but thank you all once again!
