Not sure about my 100-400. Sometimes great, sometimes subpar...
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
6
Hi,
I have been using this lens for the last 6 months mainly shooting at 400mm. What bothers me with this lens, is that there are cases where it behaves great (in terms of IQ) and times where it is subpar. I am thinking of other options, but to be honest I am not sure if I am also making some mistakes and not getting the best of it.
Below I am posting some of my best shots and in a 2nd post some of the shots I would like better IQ. Would like to hear your comments and advise.
My best shots:
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
Re: Not sure about my 100-400. Sometimes great, sometimes subpar...
5
I feel the same about my Panny 100-400.  I put it down to the fact that it's difficult and although I have had a good few years with it now, I am still liable to a lack of concentration and user ineptitude.  Not that I an accusing you of being inept.
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,309
Re: Not sure about my 100-400. Sometimes great, sometimes subpar...Part II
And here are some of the shots I would expect more. Bear in mind that pp is about the same as the good shots (LR and Topaz).
I mainly see problems:
1) in sunshine days with white objects
2) in birds near the sea
3) in smaller birds where is hard to get much details
tammons Veteran Member • Posts: 8,140
I would guess inaccurate AF and or AF not keeping up.
And the Em1 III doesn't have bird detect if you are ever having issues getting birds in focus. Bird detect helps.
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
19
the second lot clearly have problems because of the conditions you are shooting in, hazes, bright direct sunlight can all make sharpness and clarity disappear quite easily, the lens can clearly perform but in certain conditions all systems will show similar problems
the computer says no
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
Be More Regular Member • Posts: 370
This is what frustrated me with the 100-400, the lack of consistency. I should note this was when paired with the EM1III. Where I often found I would have to play with settings a lot more, especially when and when not to use the lens OIS or the camera IBIS or both in conjunction with each other.
When I paired it with the OM1 it performed much better. Actually was very impressed with it when pairing it with the OM1. However I had already been using the 200 with and without TCs and it really has been a much more satisfying experience despite not having the ability to zoom. Consistent satisfying results that inspired confidence, be it with the EM1Iii, G9 or the OM1. While the 100-400 could sometimes produce stunning results, other times it would leave me disappointed. At the end of the day, you get what you pay for. It is a good lens for the price, certainly better from 300-400mm than the 40-150 Pro with TCs that I had been using previously. Yet there is a reason the primes are priced higher.
 Be More's gear list:Be More's gear list
Panasonic Lumix DC-ZS80 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +5 more
DocBobB
DocBobB Contributing Member • Posts: 891
7
If you get good results sometimes, it’s not the lens per se.  It has to do with the conditions - light angle, haze, thermal distortion; or the operator - ISO, aperture, shutter speed, IS, hand steadiness and so on. Granted the OM1 may make it easier, but the lens itself is not at fault.   I’ve been VERY pleased with it on my em1 mkii
Bob B
In use: Olympus OMD E-M1 mkii; OMD EM-1 mki; mZuiko12~100; m.Zuiko 100-400; Panasonic 45-175 PZ; Pan/Leica 25mm f1.4; m.zuiko 75-300; Rokinon 7.5 fisheye; Zuiko 50mm macro and EC14; Zuiko 50~200 ED, fl36, old e-510.
On the shelf: e30, EC20, 18~180, 14~42, 40~150, Zuiko12~60,
tomhongkong Veteran Member • Posts: 4,723
Are you shooting using c-af on em1.iii.?  I dont have em1iii but find on em1ii that c-af shots show great variability in a burst, sometimes spot on while the next shot is terrible.  S-af is consistent but never as good as best from c-af
I just burst and discard a lot of shots!
Tom
Mait
Mait Regular Member • Posts: 494
I am experimenting similar things sometimes.
It is pretty hard to get good images out of this lens, but if i use burst with c-af then often i get few sharp ones.
Af seems to jump around quite a bit. But yes, it is also half the price of 300 pro.
 Mait's gear list:Mait's gear list
Olympus E-M5 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus M.Zuiko Digital 25mm F1.8 Sigma 56mm F1.4 DC DN | C (X-mount) +1 more
Yannis1976
Issue is I am comparing this to my Fuji setup (xt3 & 70-300) and the Fuji kit is much more consistent and of better IQ. So now I am bit torn… Should I try again the PL100-400, should I also try the Fuji XF100-400 or go for the more expensive, big and heavy 300/f4? The latter is for sure the safest bet in terms of IQ, but is also quite big and heavy for my likes…
Try the Panasonic 100-400mm and return until you find a super sharp copy.
Albert Valentino Veteran Member • Posts: 9,762
8
My philosophy when testing a lens is this, the sharpest results reflect of the quality of the glass, any shots that are not as sharp as the sharpest are a result of others factors like technique, settings, motion, light… To that end, you seem to have a sharp copy.
Also, are you using protective filters for some shots? That can be the kiss of death under certain conditions.
Truth never fears scrutiny.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
5
👍 Exactly!
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Albert Valentino wrote:
👍 Exactly!
Yes it's easy to see that lighting and atmospheric conditions are causing the problems.
800mm equivalent is a very long lens and this is to be expected. Even within moments of each other. Shoot one direction fine, turn a bit and awful.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Photongraphy Regular Member • Posts: 419
6
Totally agree.
The tech has come so far we easily forget the physics involved. Be amazed you can get tack sharp images @800mm eq handheld, don't be disappointed when you can't: it's not the gear.
 Photongraphy's gear list:Photongraphy's gear list
Olympus OM-D E-M5 Olympus E-M5 II Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye +5 more
AshleyMC Senior Member • Posts: 2,228
the scene
the light (quality, intensity, direction)
the environment (earth, water, air, heat)
the lens
the camera
the person (all sorts of crazy irrational emotional moody egoistic elements)
It’s not just “the lens” in the dynamic totality of things.
(Full disclosure: I have been using G9 + PL 100-400.)
Gary from Seattle Veteran Member • Posts: 7,852
I see a variety of problems on most of these images. Those include, miss-focus, the fact that in macro (butterflies) the creatures are very large in the image and even slight movement of the creature results in a change of focus, too high of ISO on a few images (sun), and it looks like missing getting the exposure as close as possible to accurate so that PP adds noise or gives poor whites, and probably some other errors.
In macro of creatures like butterflies and bees expect a low hit rate because of the above mostly. Shoot bursts and expect to throw 2/3 of the shots away.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
I think your lens is fine. It is just much harder to shoot at 400mm (or even 560mm with 1.4TC as in some of your samples).
Sure, if you can afford it the 300/4 is a much better lens, no question about that. But by just throwing money at the problem without improving your technique, the results may still be worse than a humble 100-400 in expert hands. I would recommend you spend the next year with the lens you have, aiming at getting an expert hand yourself. You just can't buy experience.
Only then reassess if you really still need/want the 300/4. And if the answer is yes, then you will also have the skills to make it really shine. And it will be well spent money, not just GAS.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
JakeJY Veteran Member • Posts: 5,442
I notice you aren't shooting the same FOV in your existing Fuji kit. I've seen comments plenty of times about inconsistent results with longer lenses and a lot of times it is simply because it is more challenging (you are more likely shooting a far away subject that is subject to haze/atmospheric effects on IQ, it is harder to focus, harder to stabilize).
If you shoot a Fuji with a lens in the 133-533mm range, I think that would more closely represent the same challenges as shooting a 100-400mm in MFT (add more if using a TC).
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
jalywol
jalywol Forum Pro • Posts: 12,301
9
I think your lens is performing as I would expect it to.
The only thing about the lens itself that I find questionable is there seems to be a fair bit of purple fringing on brightly lit white edges of subjects (birds). If it were me, I would see if stopping down and being VERY careful with exposure, on that type of subject, improves the CA problem.
You also have to remember that if you use a TC, you are going to radically increase the likelihood of CA on bright edges, esp if you don't stop down more with it, also.
There are other things to remember, too:
  1. If you are shooting over water, temperature gradients at the water's surface can mess the hell out of your shots. I see that in a few of yours.
  2. Distance is the enemy. The further you are from the subject, the less detail you will be able to recover in PP, and the more atmospheric distortion will affect your image.
  3. Be careful with exposure. Underexpose when you have bright subjects, or subjects with bright sun hitting part of them. (Those are difficult subjects to get right anyway). In other words, expose for the brightest part of the image, or close to it.
  4. AF can get fooled by things in the environment. I was shooting with the S5 the other day (which has DFD but not PDAF) on S-AF, and the subject was a fairly distant heron with brightly lit water with contrasty ripples behind it. About 2/3 of the shots were very nicely focused on the contrasty water ripples, and left me with a fuzzy bird, which aggravated me greatly. A couple of days later I went out again, to a very similar situation, and I used the animal detect setting, still S-AF though. It worked great; my in-focus hit rate went up to about 70%, which I consider about what I expect for me with distant birds with a long tele. So, I think you should experiment with your settings and see if changing a few shooting parameters gives you a better hit rate.
  5. Keep your ISO down as much as you can. I still try and shoot as much as I can with M43 with ISO 200 or 400, as it really optimizes the detail you can get while minimizing the noise. I understand it's always the argument between shutter speed and ISO and aperture, but as a rule, if the light is really lousy, I don't expect to get my best results.
  6. If you aren't using a monopod, consider it. Bracing and support make a HUGE difference in the behavior of long telephotos like this.
That's all that comes to mind at the moment.
-J
