Mic boom equipment
Started 6 months ago | Questions
Frank I Reiter
Frank I Reiter Regular Member • Posts: 159
Mic boom equipment
Hi every. I’m assembling my first video kit and could use some advice. I’ve bought an NTG5 mic and need a boom arm, perhaps something like this:
https://www.bhphotovideo.com/c/product/1562282-REG/k_m_25530_519_55_extra_long_adjustable_boom.html
I already have some light stands. Is there a way to mount a boom arm on a light stand so I can avoid buying a dedicated mic stand?
Is the boom arm I linked above a good value? Would you suggest something different in the <$100 price range?
Thanks in advance!
 Frank I Reiter's gear list:Frank I Reiter's gear list
Canon EOS R7 Canon EF-S 18-135mm F3.5-5.6 IS USM Sigma 70mm F2.8 DG Macro Art Canon RF 24-105mm F4L IS USM Sigma 40mm F1.4 DG HSM +1 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,109
Re: Mic boom equipment
Do you need the boom to extend that far? If you're just placing the boom beside a chair so that you can record narration, for example, then a short boom with stand is cheaper - I use something pretty similar to this and it does fine for the job:
https://www.bhphotovideo.com/c/product/755878-REG/auray_ms_5230t_tripod_microphone_stand.html
Andrew S10 Senior Member • Posts: 1,839
This light stand with a boom arm will work: https://www.bhphotovideo.com/c/product/898306-REG/impact_ls_cb6_combo_boom_stand.html
You could use a C-stand, if you find a good deal on a used one.
Frank I Reiter
OP Frank I Reiter Regular Member • Posts: 159
Thanks, Andrew.  They seem to be in sale right now.  I’ve placed an order.
Frank.
Frank I Reiter
Thanks for the suggestion.
Frank.
