Night Moves
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
Night Moves
A few stage actors from the Thrift Store
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
tripleC
tripleC Veteran Member • Posts: 4,330
Re: Night Moves
Neat. Your getting the lighting down very well. What are you using for lighting?
 tripleC's gear list:tripleC's gear list
Nikon D5500 Nikon AF-P 18-55mm F3.5-5.6G VR Nikon AF-P 70-300mm F4.5-6.3G
Rodger in Edmonton
OP Rodger in Edmonton Veteran Member • Posts: 4,599
Re: Night Moves
Thank you for the kind words TCI focus on 3 lighting methods:
1 Ambient Light
A set up a black box with black or white   pin boards  and use ambient light from a N facing window so there is no direct sunlight, I play with the board arrangement and select from a range of looks
The puppy with a dark BG is low shutter speed against a black board
2. Flash - 1 600 Ex RT wireless - either bounced off the ceiling or here with the top horse,
I bounced off a card sitting low and reflecting up  for drama.
3. Light Painting
Use a dark area with a black BG and have at it - since the sensor averages illumination,
this method can work well with objects that have pesky specular highlights, or some other wonkiness that is making the shot look bad with the first 2 methods.
Quaecumque vera
