2:1 macro lens for Nikon - recommendation?
Started 5 months ago | Questions
Bob Veteran Member • Posts: 4,423
I’d like to build a rig to digitize 35mm and 120 negs.  The negs will be backlit, so distance to focus is not an issue.  I have a FF Nikon.
I’d like to achieve a magnification greater than 1:1.  I plan to take multiple images of the negative and stitch them together in PS.
Any suggestions for a lens?
Robert Salton Forum Member • Posts: 75
Re: 2:1 macro lens for Nikon - recommendation?
The Laowa 100mm 2x Macro. Nikon F, 2:1 out of the box, flat field, very sharp to excellent when closed one or two stops. It can be somewhat soft-ish wide open, especially at infinity, but for macro work that's not an issue.
There is some slight pincushion distortion which is easily corrected.
A more budget friendly option is a reversed 50mm with extension tubes. I tried it with Nikons 50mm f/1.8 AF-D. It does work and at f/5.6 or f/8, image quality is suprisingly good in the center but the corners are a little weak and its very prone to internal reflections.
OP Bob Veteran Member • Posts: 4,423
Thanks for the tip. Since I plan to stitch images, I need to be wary of corner softness.
What do you think of using a bellows?  Would I have to reverse my lens (e.g. 50mm)?
BBbuilder467 Veteran Member • Posts: 7,057
What are you using to reach 1:1 now? Adding extension tubes to a macro lens will get you beyond 1:1.
Are you taking into account that when you go much beyond 1:1, you'll lose the vertical and might have to be in portrait orientation to maintain the aspect ratio?
Models By Day Regular Member • Posts: 399
Vivitar made a 2X Macro Focusing Teleconverter.
It does 1:1 , I think it does 1:1 with a 50mm lens. Never tried it in macro mode with other lenses.
I mostly used it as a 2x, but sometimes as a 1:1 macro
I also use a reversing ring on my 50mm lens
 Models By Day's gear list:Models By Day's gear list
Nikon Z7 II Nikon Z 24-70mm F4 Nikon Z 85mm F1.8 Fujifilm FinePix F200EXR Nikon D300 +3 more
