Fujifilm .RAF RAW file in Lightroom has worms
junkhole New Member • Posts: 5
Hello Hello, I tried to title this in a way that would help if I was looking for this issue as I have tried and failed to search for an answer to this, some people say worms, some say water colour? I'm not sure really.
Some say 'Don't pixel peak' or 'Don't sharpen' and you'll be fine. but from testing with my own Raw files from a Fujifilm X-E4, I can't seem to get a 'good' looking file in lightroom.
Backstory is I've used Canon DSLRs and lightroom for 10+ years but recently I sold everything and moved to a LOVELY fujifilm X-E4. I saw that fuji had a special Capture one fuji version that apparently handles the simulation profiles etc so I got myself a copy of Capture One and have been trying to use that along with lightroom to see which is 'better'
I've found that I don't really get on with capture one for different reasons, Not being able to change the UI in some ways, the ingest, pick/reject tools and exporting.
So I was going to go back to lightroom when I noticed that my images in lightroom have a strange surface quality, some might say worms? squiggles? However doesn't show up in Capture One. In Capture One these details terminate differently and im many ways appear nicer.
"Don't zoom in" would be an option but I can still see them when at 100% and I noticed they also effect out of focus sections. i'll attatch some images to show what I mean
Lightroom and its surface worms, look in the purple section for knots and then look at the out of focus flowers which have a strange banding issue
In capture one the flowers are blury and soft and the purple section doesn't have the worms
Capture One on the left and Lightroom on the right
My question to my fellow fuji users, am I missing a tickbox or something in lightroom to stop it from doing this? I don't want to use Capture One but my raw images look rubbish in Lightroom.
Erik Baumgartner Senior Member • Posts: 6,893
Re: Fujifilm .RAF RAW file in Lightroom has worms
Optimal sharpening and NR settings in Lightroom depend somewhat on the particular image. Lightroom's X-Trans demosaicing can indeed contribute to processing issues (especially sharpening) with some images, but can usually mitigated to some degree with carefully applied settings or eliminated entirely by using "Enhance Details" or Iridient X-Transformer in place of Lightroom's standard demosaicing. If you'd care to share a link to your RAW file, I'll be happy to see if I can get a better result with just Lightroom. I use Iridient X-Transformer, but Lightroom alone can usually produce a perfectly decent result with most images.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP junkhole New Member • Posts: 5
Right click file in lightroom and click "Enhance Details" then process the file with the popup, it fixes the image so it renders the same as Capture One.
Seems like I found out the fix 5mins after my first posts. its always the way
Anyway, for others. This is how
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Looks like you found the magic “worm killer.”  Well done, and welcome to the forum.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
Yes, silly me was 1 search away! I had looked into this twice with lots of contridication but hopefully my post here can help another, Now all I need to do is figure out how to select all the .RAF files and delete them in lightroom so I can carry on my edit with the better files.
Also its a shame the newly created DNGs don't seem to preview in windows like the RAFs did
Jerry-astro
6
Maybe it's just me, but I never delete RAF files for any of my "keeper" images.  There can be processing improvements in future versions that might give you an incentive to reprocess some of your images.  I look at RAF files as digital negatives and only delete those that I don't regard as keepers.  Storage is cheap, so that might be something for you to consider.
Jerry-Astro
Fuji Forum co-Mod
Don’t delete the original RAFs. Copy and paste all your development settings back to the RAF and delete the DNGs if you must, you can always recreate the finished DNGs later if you want revisit your editing at a later date.
a_c_skinner Forum Pro • Posts: 13,047
I'm not a big post processor, indeed I'm not much of a photographer, but like others I never delete the camera raw files.  I am trying to be more intelligently selective about what I keep, indeed about what I photograph at all but storage isn't costly.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Morris0
Morris0 Forum Pro • Posts: 32,175
You need to load a codec pack to support some types of RAW files in windows so that Windows Explorer will show them. This is one:
https://photographylife.com/how-to-view-dng-thumbnails-in-windows
There are many others.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
I do have fastpictureviewer codec installed and these HORRIBLE dng files from lightroom still error out windows and won't open in the "windows photo viewer"
When I used to convert my .CR2 canon files with adobes dng converter, they'd still open in windows but these enhanced .dngs won't
also they are DOUBLE the size, what is going on here???
opening one in "photo viewer" on windows 10, it loads a really low quality jpg fullscreen and pops this error
I would use the photo viewer on windows but you can't go left and right with the side mouse buttons and it takes longer to open than the "windows photo viewer"
Is this adobe pushing BRIDGE?
Wish I had the money but each HDD I buy I have to buy it 3 times, I don't need every dng of everything forever. I don't remember the last time I really went back in and re-edited an old photos, What I did at the time was what I chose and i'll live with it.
Morris0
It's been a long time.  I think I uninstalled fast picture viewer.  I wish I could recall all the details so I could help.  I just looked in a folder with large icons selected.  It only shows me the DNG files.  No RAF.  I use Adobe Bridge to view them.  I suspect this is my solution and at least I got rid of the Windows Explorer crashes.
Morris
deednets Forum Pro • Posts: 13,887
Morris
Interesting registry item! Tried it and it works after all these years I still use Windows photo viewer for a "quick" (emphasis on speed!) look. I can now see DNG files now and open them with a 6 nano-second click ... most other viewers I have used take longer when all I sometimes want to do is have a quick peek.
Thanks for the link
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Nielk Mike Senior Member • Posts: 1,480
There is the Enhance option in LR and certain settings in sharpening to achieve better results. But fankly, still not good enough.
Get a trial of DxO PL5 and apply only the lens profile and NR. Then export DNG and open in LR. Much better results.
fabienb New Member • Posts: 1
It's becoming old but still my most viewed post on my blog... If you're not keen on duplicating files or using DNGs, I show you my tests and results for an optimal result in LR here: https://fabienb.blog/sharpening-fujifilm-raw-in-lightroom/
It probably needs updating now, with the recent software releases, but it still seems to be valid for LR.
baobob
baobob Forum Pro • Posts: 18,248
The old legend again !!
Just by a wormicide or work in depth with the ACR engine....
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
It is not a legend, and the difference to DXO PL6 is very noticable.
It is not just about sharpening. The demosaicing in DxO PL6 seems to do a completely different job with Fuji files that LR does. Leaves, gras and other (mostly green(ish) ) details are much better defined and hence cam be sharpened without issue. So I rather have a DNG fine on top of my RAF file.
baobob
I did not find any signifiacant difference. Probably ACR demands a bit more attention and time. Coupled with IXT, or enhancing details give similar results. That was true in the past bur Adobe did improve the program. Comparison with C1 also did not show me any significant difference as well.
So coming back now with observations of the past looks for me as talking about a legend
My experience differs. Even with Enhance, LR doesn't not create a file that renders foliage as sharp as DxO PL6 and with the potential to use sharpening agressively. One can do with LR - but it is a more complex process whcih often works, and sometimes doesn't. Lr has certainly come some way from the past "worm infection". But it is not just a legend.
