glare or highlights on black beetle - poor diffuser ?
OP jim mij Senior Member • Posts: 1,027
Re: Thanks for the idea
Hi Mike
i had a thought, perhaps leave a baffle to get rid of the hotspot, but use a larger 2nd diffuser closer to the lens to even out the light before it reaches the subject ? Should be easy to hand hold something to test that out
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Distinctly Average wrote:
It also looks like your light source could be closer to the subject. That effectively makes it larger and more diffused
hi DA, I agree, I had ripped up my diffuser and ended up with something half the size of the lens, too close to the flash and to far away from the subject, all the guides say large and wrapping the subject is best which is where this post originally started before I deviated away.  Buy or build….
Jim
Mike Engles Senior Member • Posts: 2,573
I have tried that, but the light loss is considerable as the inverse law come more into effect as the light is even further from the subject, together with the loss from the second diffuser.I don't want to use 1/4 power or even 1/8 as a little too much daylight intrudes, so with moving subjects you can get double images.
This was at 1/4 power as I was some distance away. The wings look good, but the features are not as sharp as they should be could be or the focus is off a tiny bit. This was only x.5.
This is how I use it, the head can be very close, not generally as close as this, except for x2 or x3 (just about) I rarely go beyond x2
It can move around the subject to some degree and is not too front heavy.
I used to have a different arrangement with a second arm that could either have a LED light or a reflector, but that just got in the way and was really front heavy.
