A6600 EVF intermittently working
MotoDave Regular Member • Posts: 133
So I bought this new A6600 about a month ago and I have it set up so the live view goes to the EVF when I raise it to my eye, which is how I want it to work.
Within the first week of ownership I had an instance where it did not do this automatically, but a simple power cycle solved the problem. I figured it was a glitch and moved on. Since then it has done this a couple times with the power cycle fix.
Within the last few days the power cycle does not solve the problem. It just randomly works or doesn't with no rhyme or reason. I've tried wiping the eye/light sensor area clean to see if that was the culprit and doesn't seem to make a difference. I'm not aware of any setting that would cause this intermittent behavior.
Every search I do to see if this is a common problem gives me results for when it switches to EVF when not wanted, not the problem I'm having.
So, thought I'd check here and see if this is a known issue with any easy fixes. I'd rather avoid the having to deal with sending in a brand new camera for a fix.
JS_Photo_Hobby Forum Member • Posts: 81
Re: A6600 EVF intermittently working
I had something similar w the 6500. I wasn't using the eye cup for the EVF because I wear glasses and found it got in the way. But, without it not enough light was blocked to trigger the EVF. I ended up buying a different eye cup with a larger cup shape, no more issues.
Dunno if that is the same for you.
-JS
 JS_Photo_Hobby's gear list:JS_Photo_Hobby's gear list
Sony RX100 VII Sony a6500 Canon 6D Mark II Sony a7R IV Sony a6600 +12 more
OP MotoDave Regular Member • Posts: 133
JS_Photo_Hobby wrote:
I
-JS
Hey, thanks for the reply, and worth checking again, but that is not the case with mine. I can cover the entire viewfinder with my thumb and sometimes it doesn't work.
