4K video editing
Ron Zamir Senior Member • Posts: 1,421
4K video editing
Complete beginner question:
I have to edit video in which I have to mix 4K and 1080 HD clips and save it as 4K.
What will happen to the 1080 HD part of it? How it will look?
Alternatively, if saved as 1080 HD how will the 4K parts look?
Or in another way to ask it - how mixed video clips (4K and 1080 HD) should be edited together?
 Ron Zamir's gear list:Ron Zamir's gear list
Olympus E-1 Olympus OM-D E-M10 Olympus E-PL8
Joe Lynch Veteran Member • Posts: 3,185
Re: 4K video editing
Shouldn't be a problem to export the mixed video in 4k.  The 1080 should look a little better and the 4k rendered in 4k won't be a problem.  You can try rendering the edit both ways and see for yourself.  The exported 1080 file will be much smaller than the 4k version and will upload to Youtube a little faster.  The exported 4k file will be larger and take longer to upload, but will be a little cleaner when played back on a larger 4k monitor.
 Joe Lynch's gear list:Joe Lynch's gear list
Sony a1 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro +5 more
Gary3000 Senior Member • Posts: 1,510
Not a problem, people mix-n-match different resolutions all the time
Depends on the editing program and how/how well it decides to "up-rez"/process the 1080 to fit the 4k frame.  Some editing programs might have fancier algorithms that can make HD look nearly as good at 4k.  Others might just merely double up the lines/pixels.
That also depends on the editing program/process.   Some editing programs might down-scale the 4k, making for super-sharp imagery, others might merely toss every other pixel, which is still ok.
Well, if you know for 100% certain that you're only going to output at 1080 HD,  probably ideal to edit it all in a 1080 HD timeline, just for the sake of faster editing/processing/storage,. etc.
But most will probably recommend sticking with editing at 4k if you can, for the higher quality results in the end, particularly if down the line you want to export or share a 4k version.
As mentioned, try experimenting to see what your results and workflow are like just to see for yourself what the differences are and if you can notice the difference in the results.
 Gary3000's gear list:Gary3000's gear list
Sony RX100 V Canon EOS 5D Mark II Sony a6500 Canon PowerShot G12 Canon PowerShot S110 +14 more
low_iso Regular Member • Posts: 272
5
Lets clear up some mythology flying around here.
1. All NLEs will scale your video for you to whatever specs you choose for your project
2. Scaling video does not improve it. Ever. There's no magic here. Up-scaling 1080p to UHD (NOT 4K!), which is 3840x2160 is an even multiple. That means within a line every 1080p pixel is faithfully reproduced, and the missing pixel inbetween is created by assigning an interpolated value, and the ineropolation is simply linear. What you get is a 3840x2160 blow up image of a 1080p image, but it isn't improved, it's just a blow-up. There's no magically creating detail that didn't exist in the original. It's still just a 1080p image, and it will look like a 1080p image, though content of the image may not show that it's really a bit softer than the 4K footage.  Or it might.  The exceptions might be 3rd party apps and plugins like Topaz Video Enhance, because it does SO much more than the upscaling found in NLEs. It applies several content-aware AI based processes.  It also takes an eternity, and results vary a lot from flat out amazing to unusable.
3. Scaling video can degrade it.  If you attempt a scaling that isn't an even multiple, like 1080p to actual 4K (4096 x 2160) you'll end up degrading the 1080p image because it won't scale evently. Much more interpolation must take place, there are no even pixel relationships at all, if you want to fill the 4K frame.  Mostly when that's done it ends up just as a 2x scale and not filling the (real) 4K frame. Full up-scaling to real 4K should be avoided.
4. Down-scaling UHD/3840 x 2160 is again even math.  You can't represent the resolution of 4K at 1080p, and because it's a simple conversion, there are no real image gains here.  There will be no gain in sharpness doing that.  What you can get is the ability to crop the UHD footage without taking as much of a hit as cropping the 1080p image.  For example, if you use image stabilizing in the NLE, that process must by definition crop the image so it has room to stabilize it.  It's a good trick to shoot 4K in anticipation of stabilization in post (as is to shoot it with a higher shutter speed for stabilization).
Where you often do gain quality in down scaling is if you're output is something like a DVD, 720 x 480.  There is no even mathmatical scaling from 1080p or UHD to get to 720x480, but because that resolution is already so low, and there is so much more information in 1080p, you actually can get an apparent image improvement over shooting native 480p, particularly if the DVD is anamorphic.  That's if anyone actually does that anymore.
Since you say your end project has to be in 4K (hopefully UHD, not real 4K), then you should work in a 3860 x 2140 project and timeline.  Let the NLE up-sample the 1080p footage.  It'll be fine, and depending on the content, may not even be noticable that it's not UHD.   I agree that editing in a 1080p timeline is faster and easier, but there's no point if the final output is to be UHD.
apekkpul Senior Member • Posts: 1,497
Resolve has ”super scale”, similar to Topaz VE. I assume these kind of funtionality becomes more common. Photoshop does sometimes miracles by inventing content…
 apekkpul's gear list:apekkpul's gear list
Sony a7 IV Panasonic Lumix DC-S5II Canon EF 24mm f/2.8 Canon EF-S 55-250mm f/4-5.6 IS II Canon EF 24-70mm F4L IS USM +12 more
Actually,  in todays world of NLE editing apps, there IS "Magic". that magically fills in the missing pixels while retaining sharpness.
Not all NLE's do it, or do it the same.
Davinci Resolve (which is one of the most popular NLE's on this forum) has super scale, Adobe Premiere (via After Effects) has Detail Preserving Upscale. (not to mention AE natively offers different options on scaling  - BiLinear or BiCubic, the later is better for non-graphic elements)
Also keep in mind that 1080i footage needs to be de-interlaced prior to up-scaling,  in which case there is the "Preserve Edges" option in After Effects (maybe Premiere?). that also makes footage look better than just scaling it up using nearest-pixel.
and yes. all this technology does indeed improve the appearance of upscaled 1080 video, even that which has been upscaled to "true" 4k. (which honestly,  is irrelevant to the OP's question, as very few work in true-4k).
But just like with photographs that have been scaled up 200% in Photoshop, video scaled up 200% will look better.
^^^ this
Perfect example of not all doing it the same.  I was referring to basic scaling, not multi-algorithm or AI processes, the results of which range from spectacular to unusuable.
Irreelevant to the OP's question, I believe.  1080i should no longer be part of anyone's discussion these days, unless they're dealing with archival footage.
Um...no, not all, and not with all footage.  The problem is that algorithms must make certain assumptions, and the assumptions are not always correct.  Some content defys analysis. That's when manual tweaks and human judgement come it.
Yikes, well, that's not true!   Photoshop scaled images have more pixels, not more detail.  The faked detail in 3rd party still or video algorithms comes from some rather intensive content prediction that fakes the detail.  But, look at that detail carefully, and closely.  It's not real, nor does it hold up or work well on close inspection.  Great at a distance only, and very sensitive to specific content and some extremely touchy manual parameter input.
^^^ this
But most of them do, or are capable of it.
and even without AI assistance, they fill-in the blanks, many with algorythms
Basic upscaling does a fine job of upscaling, ones that use algorithms do it even better, and  AI assisted upscaling does an even better job.  is it ever "unusable?"  nah.
99% of cameras can shoot 1080i and 1080i it's still the most dominant format being broadcast.
You should do a test,   open up a 1080 movie on your computer monitor and make the window 4x as big.
Then save a movie that's been upscaled it to 4k and view it at 2x as big, and view the movies side by side.
the 1080 will eventually look pixelated, while the 4k/UHD will still hold up better, because it has additional pixels and those additional pixels have additional detail that's been added by the algorithms. -even "nearest neighbor" looks better, toss in a sharpening filter (which all NLEs have), and it looks even better.
Yes, live broadcast in the US is still stuck at 1080i, at least for now. Nobody produces content (other than live) in 1080i though. ATSC 2 (current) maxes at 1080i, but ATSC 3 includes 3840 x 2860 UHD and up to 120frames, wide color, blah blah...lots of stuff that should make content producers ditch 1080i now for future-proofing if nothing else. ATSC 3 has been approved for the US, and has been used at the 2018 Winter Olympics. Relative to the OP's question, 1080p will scale to UHD better than 1080i in most cases.
My comments were based on my own tests. I don't find the basic NLE adding any significant detail when scaling.
