Recommended Travel Friendly Macro Tripod
Started 5 months ago | Questions
gugim Junior Member • Posts: 32
Greetings,
I am looking into carrying a travel friendly (small, light) tripod I could use when photographing mushrooms or early morning insects, and that could double as a monopod maybe for using with birds.
I have a light system (Olympus OMD 1iii) .
Currently I am considering the Peek Design Traveller tripod.
Any recommendations will be appreciated.
Thank you,
Ariel
 gugim's gear list:gugim's gear list
Canon EOS 5D Mark III Fujifilm X-T20 Olympus E-M1 III Fujifilm X-T5 Canon EF 50mm F1.4 USM +14 more
EarthMurmurs Regular Member • Posts: 475
Re: Recommended Travel Friendly Macro Tripod
I am an avid fungi photographer. My goal is to take shots as close to ground level as possible, to show a perspective unseen by humans who tower over these small, fascinating organisms.
To achieve this, I have a tripod with the centre column inverted, which allows my camera to be at ground level, and very stable to set up 10-20 shots on manual focus, which are then stacked when I get home.
This does mean operating the camera upside down, which takes some learning. Fortunately my camera has tilting display, so I do my focusing and metering from the screen.
meow
meow Veteran Member • Posts: 5,751
gugim wrote:
Greetings,
Don't know if it fits your needs, but have you looked at ifootage Cobra monopods? They have this "tripod foot". You can remove the foot part and the head part and put them together to get a mini tripod with ball head (or whatever you use on top). Very quickly done, brilliant quick releases. The angle of the legs of the mini tripod can be varied, there are three or maybe four stops, don't have it handy so I can check.
https://www.ifootagegear.com/collections/monopods
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
Woody S
Woody S Contributing Member • Posts: 742
Get yourself a Platypod or something similar and put a ballhead on it or just use a bolt and/or quick release plate on it and you can get your camera down very low with very little weight.
maggiemole Senior Member • Posts: 1,987
What make is your tripod? I have a heavy Hama Traveller Compact Pro which allows me to invert the centre column, but the head is large and fixed and gets in the way of the tilt screen on the camera from my viewpoint. Something lighter and perhaps with a detachable head would be better for me.
thanks
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
BBbuilder467 Veteran Member • Posts: 7,057
thanks
With a ball-head, it shouldn't matter whether it's right side up or upside down.
With a little travel tripod, you might not have to reverse the column. Just invert the legs. I don't know why the ball-head would get in the way.
Dann-Oh Contributing Member • Posts: 894
meow wrote:
gugim wrote:
Greetings,
I'm an avid ifootage user, I have the Cobra 2 C180-II monopod and TC2 Fastbowl with Komodo K5 fluid head tripod kit.  The Cobra does have a mini tripod, the mini tripod at its lowest setting is about 6inces tall BEFORE adding any ball or fluid heads, however the mini tripod does have a ballhead built into it.
I have used the mini-tripod with my Olympus 40-150 F2.8 pro and my Olympus OMD EM 1-3 without issues.
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
thanks
You're right, BB. It took me some time to work out that I needed to mount the camera at 180 degrees to the normal position on the head. Now the attachment controls (if that's what they are called) no longer get in the way of the view of the tilted screen, at the small inconvenience of awkwardness in releasing the camera at the end of the session. Thank you!
I have the Cobra 2 mini pod as well, but the camera still ends up too high from the ground. I'm aiming for an inch or so for these tiny mushrooms. For small flowers, it is perfect!
I've been looking at the PlataPod but I'm not too sold on it. I prefer to use a fluid head but they are pretty tall so im not too what to do myself.
thanks
Hi Maggie - the tripod I use for inverted shooting is an Inca i5315, and I replaced the stock head with a cheap, compact Neewer ball head. I chose this head because it doesn't have a panning arm to get in the way.
I've seen this tripod on FB marketplace from time to time for around $20 (used) and the ball head was also around $20 (new)
StevenJR New Member • Posts: 8
Avoid that neewer ball head. The rubber on the knobs slips badly, and it’s a bit heavy.
R
R
Yes, what a stupid design. Two of those rubber rings have disappeared from mine. Knurled knobs would have made for a better product. Alas, you get what you pay for, and that head is $20.
Re: Recommended Travel Friendly Macro Tripod - for fungi
Thanks for your recommendation on tripods. I’m still investigating but hadn’t considered the detachable ball head versions. I have a quite useable Fotopro head which would be part of the solution.
Right now, I’m more interested in your fungi expertise - especially if you live in southern England. I find that local forests have been much disturbed by extra leisure activities and dog-walking since the start of the pandemic and lockdowns, and fungi are hard to find. If you know of fruitful places I’d welcome knowing them. Google isn’t helping much. Thanks!
Maggie
I won't sugar coat it - hunting for fungi is hard work. You will get very dirty, you'll walk for hours at a time in dense forest, many days finding nothing at all. My greatest finds have all been well off any established walking trails. And usually a very long way from my home, 2+ hours driving.
I've been attacked by dogs, came home with mysterious skin irritations, been bitten by swarms of fire ants, struck at by a snake, swooped on by agressive birds, sustained ligament injuries. Yet I still keep chasing that next beautiful specimen.
Is it worth it ? For me, yes. I enjoy searching for less common things to photograph. Here's some of my finds over the past two seasons:
https://earthmurmurs.com/fungi/
Can't help you with locations in England, as I'm based down under. But if you have FB, there's a very active private group called "Fungi of the World", maybe you can join the group and shout out to members who could recommend some spots in the UK
Good luck, and I hope you find some funky fungi on your travels
I probably use the column reversed more than upright for nature subjects, so it's easier with a single action ball-head with a lever. Then, you can just float the camera into position and lock it down. You're in an awkward position anyway and you don't have to think about the thumbwheels. It doesn't matter where the lever is. You just flip it to add tension. Being upside down, it doesn't take much to hold it. It's quick and easy when you have to keep moving the tripod around.
The single action head might be why I don't hesitate to use the column reversed. There's no effort involved. With the gear below, it doesn't take much of a tripod to support it.
Bobby2Shots Senior Member • Posts: 1,121
Shooting upside down? Use an "L" bracket.
Hello EarthMurmurs,
There's no need to shoot upside-down if you have an L-bracket for your camera. Using the same set-up you're using now,,, with the column inverted,,, just drop the ballhead's top-plate into its' 90* portrait-notch, then attach the side of your L-bracket to the ballheads' quick-release.
Veni, Vidi, Velcro;
I came,,,, I saw,,,, I stuck around.
 Bobby2Shots's gear list:Bobby2Shots's gear list
Canon PowerShot A620 Sony RX100 III Panasonic FZ1000 Nikon Coolpix P900 Nikon D810 +18 more
Re: Shooting upside down? Use an "L" bracket.
You are a GENIUS . While I've become somewhat familiar with using the camera upside down, it would be a HUGE quality of life improvement to be able to read the light meter from the top LCD display. I'll definitely look into an L-bracket setup for the 2023 season.
Thank you so much for the suggestion.
richj20 Forum Pro • Posts: 10,181
Photographing low to the ground
The VariZoom VZTP760 has two center columns: one is 3", the other 12".
The short column permits the tripod to lay almost flat on the ground, as the 3-section legs can be adjusted to the desired angle needed.
It's been my travel tripod for 7 years. 3lbs, 22' collapsed.
With the short center column, the tripod height is 50" which is fine for me for landscapes, so I don't use the longer column.
Re: Photographing low to the ground
richj20 wrote:
Thanks for the suggestion The image you shared.... isn't positioning the camera anywhere near low enough for the shots I go for. With my inverted column method, I can have the camera body suspended 1/2 inch from the earth. There's no gains for me using a tripod like the one you shared, if that's the lowest to the ground it can go. I do not want to be pointing down to the subject, I want to be level with it where possible.
I have actually considered buying a second identical tripod to the one I own I use, and completely sawing off the centre column, but haven't bothered, for the reasons outlined above.
