RF 16mm vs Sigma 12-24mm f/4.5-5.6 DG HSM II
Amefra New Member • Posts: 13
Hi
I'm afraid it's usual comparison request.
I have a R6 - having come from a long line of Canon SLRs, all the way back to film. I'm gradually replacing a lot of the old EF glass with RF; not necessarily L lenses, as I find the RF primes very good for what I need and do.
I have a legacy Sigma 12-24mm f/4.5-5.6 DG HSM II. I like it; it's not the best lens, but it's nice and wide, and as I spend quite a bit of time on the wide open beaches of Norfolk (UK!), I use it a lot. And it works on the R6; no issues at all really.
I've also read many bad reports of the RF 16mm.
But - the RF 16mm is small, throw in pocket size. And of course faster. Ideal for taking another lens, and then being able to swap when an opportunity arises. The extra size of the Sigma, and the adaptor means I'm less likely to carry it, and therefore less likely to use it. Neither lens is something you can really just leave on for general snapping. If I did swap, I would be losing that extra 4mm, which is a quite a lot at this focal range.
Anyone use both? Anyone have any opinions on which direction I should go? Should I just get a better bag?
Many thanks
 Amefra's gear list:Amefra's gear list
Canon EOS M100 Canon EOS R6 Canon EF-M 22mm f/2 STM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +3 more
Canon EOS R6 Canon RF 16mm F2.8 STM Sigma 12-24mm F4.5-5.6 II DG HSM
robcio_m Forum Member • Posts: 72
Re: RF 16mm vs Sigma 12-24mm f/4.5-5.6 DG HSM II
My idea is to have RF 16 just in case on a backpack or bag and if I see occasion to use it I'm using it.
as a casual (using from time to time) wide angle lens (if you are ok with correction in post process thats are really needed) this lens is OK.
If you focus of intrest is a landscape and you mainly uses wide angle lenses on your daily basis I strongly suggest to find better solution or stay with your current lens.
 robcio_m's gear list:robcio_m's gear list
Olympus OM-D E-M10 II Canon EOS R Canon EOS R7 Canon EF 70-200mm F4L USM Sigma 150-600mm F5-6.3 | C +3 more
OP Amefra New Member • Posts: 13
thanks
the sigma would be on (or at least with me) 2-3 days a week I guess. Possibly not always needed or used.
But then there are times I just want to travel light, and that of course is when you find you need a wider angle than a 24mm
I know speed isn't generally an issue with WA, but there are times I take a photo inside with the Sigma, and it's just too slow. That extra few stops with the RF 16mm could come in handy. And yes, I accept the amount of processing needed to produce a viable image.
drsnoopy Senior Member • Posts: 1,216
Amefra wrote:
Hi
Many thanks
I don’t personally have experience of the Sigma 12-24 but always like to have an UWA, so have had EF 17-40, 16-35 and now RF14-35. However I don’t always carry one, and that is where the tiny RF16/2.8 is perfect. Most criticism of the 16 comes from those who are either unaware or unwilling to accept that it is specifically designed to be used with software correction. With a profile it is actually very good - I’ve made A3+ prints which stand comparison in the corners with results from far more expensive lenses. Viewing at 100% or 200% on a monitor looks worse than on a print! What you will notice is that the corners don’t improve much at smaller apertures (f4-5.6 is optimal), and due to vignetting correction (which is also necessary for most UWA zooms), high ISOs may give more noise in the corners as they have to be lifted more. The best profiles in my view are Canon’s own DPP, and DXO Photolab. At the price it’s an easy option and super easy to carry. Also if you crop to the equivalent of about 20mm you avoid some of the corner issues. I wouldn’t be without it.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
many thanks.I'm coming around to the view I should be getting the 16mm...and selling the Sigma. At some point
sportyaccordy Forum Pro • Posts: 20,562
IF 16mm is OK I'd def be looking at the 15-30 STM
Has *slightly* less (but still ridiculous IMO) distortion on the wide end, but is way more versatile IMO and of course goes wider. If you turn off distortion correction it might very well be a 12mm fisheye
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
