Repair AF on Nikon 24-70
Started Sep 27, 2022 | Discussions
hypercore360 Senior Member • Posts: 1,951
Need to try and get the AF motor/electronics fixed on my Nikkor 24-70 (non-VR).
Does anyone know of a shop here in the U.S. that does the work (I'm sure there are). The item is well out of warranty for many years now.
In the end, it may not be worth fixing, and just use it as a MF lens. That can work well enough with focus-peaking.
Any input, thanks ahead of time.
Cheers
Michael Benveniste
Michael Benveniste Veteran Member • Posts: 6,724
Re: Repair AF on Nikon 24-70
I was very satisfied with the work done by https://www.nikoncamerarepair.com/.  Such a repair will not be inexpensive, though.
Good luck however you decide.
Light travels at 2.13085531 × 10^14 smoots per fortnight. Catch some today!
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D800 Nikon 1 V2 Nikon D7200 Panasonic Lumix DMC-GX85 +49 more
OP hypercore360 Senior Member • Posts: 1,951
Thank you Michael !
I'll check them out.
Cheers
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 20,431
If it is just electronics, might be easier in some ways than you think.   There are probably a bunch of old 24-70 g's with a case of zoom grind for sale cheap.   Good source of parts as long as you don't need the barrels or zoom mechanism.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +46 more
I know it can be fixed. The electronics are shot. It's just a function of how much $ to fix.
Cheers
I made initial contact with these guys today... Someone is supposed to get back to me to further discuss the details.
Let's see what happens.
