Tank Firing
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
Tank Firing
Tried for a " discus" style shockwave but ended with a cone, and I just realized  I should have the trees with a slight bend for the wind.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
tripleC
tripleC Veteran Member • Posts: 4,330
Re: Tank Firing
Neat. How'd you do that?
 tripleC's gear list:tripleC's gear list
Nikon D5500 Nikon AF-P 18-55mm F3.5-5.6G VR Nikon AF-P 70-300mm F4.5-6.3G
BlueRay2 Forum Pro • Posts: 14,816
Re: Tank Firing
cute
The eye sees all but the mind shows us what we want. w, Shakespeare
Rodger in Edmonton
OP Rodger in Edmonton Veteran Member • Posts: 4,599
Re: Tank Firing
I looked at tank firing pix and then made a cone in PS 3D mode.
I rasterized that and scaled it to the tanlk
then I filled the cone with the blast color, and gave the whole thing a Gaussian blur.
After it was done, it looked a little flat so I thought to make a classic 3 layer cake scene by putting the palms and blowing sand.
The blowing sand was drawn in in hard mode and blurred slightly.
Wind over objects ic a pretty easy effect since we know how it flows - the secret sauces are the hard brush and a slight blur, too much blur and it looks too foggy.
I kinda botched the foreground and tried to save it with the trees- I didn't want the terrain to look the same as Tank Battle
Quaecumque vera
