Andy01
Re: First Time Settings Question...
John Retsal wrote:
I'm going to try my hand at some wide-field Milky Way photography.
Camera is Nikon Z6II with the Z 14-30 f/4 lens.
I shoot Canon, but I think that Z6 ii is a FF ?
A f4 lens is always going to be challenging without a tracker. Just doesn't let in enough light.
Location has Bortle 2 skies (for those who know what that means), so pretty dark.
I'd be shooting at 14mm and maybe 20mm, wide open at f/4 tripod mounted, no tracking and VR off.
And I assume accurate MF using the screen's maximum focus aid magnification ?
I'm pretty sure I need to keep my exposure times (per the NPF rule) to around 11 sec for 14mm and 8 sec for 20mm in order to have no trailing visible.
Seems a bit conservative for a FF - Rule of 160 ? I use Rule of 300 on my 6D ii (FF) as a guide.
I would think that you could go to around 20 seconds at 14mm and 15 seconds at 15mm, which would be an extra stop of light.
What I'm unsure about are other settings such as ISO (taking into consideration the camera's ISO Invariance) and white balance.
And a bonus question, is there any advantage in shooting in b/w in terms of the quality of the images?
I wouldn't think so since there is a fair bit of colour in the Milky Way. Have a look at Roger Clark's website (as linked above) - lots of good info there. Also use a Daylight WB setting for best results.
Thanks all!
Personally I don't like doing mosaics (multi-row panoramas) in total darkness, so using a 50mm lens as suggested above just doesn't give a wide enough FoV for Milky Way (with single shots), but to each their own - depends on how comfortable you are doing panos at night.
