Can you folk recommend a better tool than Helicon-focus when.....
Started 6 months ago | Questions
areallygrumpyoldsod
areallygrumpyoldsod Senior Member • Posts: 1,042
Can you folk recommend a better tool than Helicon-focus when the lens you are using has significant focus breathing across the nearest to furthest focus point in a stack.
I tried using layers in PS and it did not work either.
The following was a render of a 40 shot stack of a subject at 433mm shot with an X2D-100C and 120/3.5 Macro lens, shot tethered and all focus shifts performed remotely (so there should not have been any movement) and I wasted far to long trying to fix the issues.  I will shoot again from further away to see if I can reduce the issue.
All raw images are imported in to phocus where precisely the same adjustments/settings and lens correction algorithm is applied to all images.
F/9.0 1/160th ISO 64 -- lit by strobe
Some images when shot a little further away (820mm) turned out better.
f/8.0 1/160th ISO 64
areallygrumpyoldsod
 areallygrumpyoldsod's gear list:areallygrumpyoldsod's gear list
Nikon Z9 Nikon Z 24-70mm F2.8 Nikon Z 70-200 F2.8 VR Nikon Z 14-24mm F2.8 Nikon Z 50mm F1.2 +25 more
areallygrumpyoldsod
OP areallygrumpyoldsod Senior Member • Posts: 1,042
Re: Can you folk recommend a better tool than Helicon-focus when.....
ajm057 wrote:
My question was answered on FM -- Helicon Focus has settings in preferences than when changed provides more latitude for the program to correct the images.
areallygrumpyoldsod
