Is 30fps Video on the Sony A7RIII 29.97 DF or NDF?
Started 7 months ago | Discussions
rdbot Regular Member • Posts: 248
Can't seem to find an answer to this. I have a Tentacle Track E audio recorder that I need to match the frame rate to my camera. I found that 30fps is really 29.97fps but not whether it's drop frame or not drop frame and this is a setting I have to choose on the audio recorder. It offers me both options. Any ideas?
Sony a7R III
mkfed
mkfed Regular Member • Posts: 224
Re: Is 30fps Video on the Sony A7RIII 29.97 DF or NDF?
Normally 29.97fps is by definition DF since timecode can only represent full seconds? But you can verify yourself, record one hour with both. If they are in sync at the 1:00:00.00 mark it's okay if they're 3.6 secs off change the DF setting?
 mkfed's gear list:mkfed's gear list
Sony a1 Samyang 12mm F2.0 NCS CS Sony FE 90mm F2.8 macro Sony FE 100-400mm F4.5-5.6 Sony FE 35mm F1.8 +5 more
OP rdbot Regular Member • Posts: 248
I found a way in the camera settings to choose drop or non-drop frames.
