Some Osprey sequences for comparison (Warning, Long...)
Started Sep 23, 2022 | Discussions
TBLF Senior Member • Posts: 1,549
8
I was looking to compare heavily cropped K1 Osprey shots with the 150-450mm with those that are uncropped or nearly uncropped from the K3III.
Dean has a barn burner of a post going, and we decided I should post a set here as well for giggles.
As you scroll down, the first one's are cropped almost 100%, you are basically pixel peeping these, and it's amazing the K1 holds up to that scrutiny, which is great, but I'd much rather have a reasonable 600mm option. Also I keep wondering how the K3III RAWs handle such abuse.
The closer you get to the bottom pic's, they are slightly less cropped, and it really starts to help the image quality.
I dunno... I'm torn between what I find acceptable and a pain in the butt and what the body/lens combo is capable of. Don't get me wrong, I love the 150-450mm, it's awesome, and the K1 output is awesome, but I would love the K1 a whole lot more with faster AF, faster cpu, and a 200-600mm lens option.
The compromise I am researching is the extra pixel density of the K3III, with faster AF, along with my 150-450, will I be happy?  I haven't tried the 1.4x, but never have been a fan of any multipliers, they usually slow things down and degrage to a similar quality as just cropping does anyway... so here I sit with this post. Try not to laugh too hard, and let me know what y'all think.
Thanks!
EricV
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/5.6 450.0 mm 1/800 iso100
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/2500 500
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/1600 iso200
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/1600 iso160
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/2000 iso250
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/2000 iso400
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/2000 iso640
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/2000 iso320
Pentax K-1HD PENTAX-D FA 150-450mm F4.5-5.6ED DC AWƒ/7.1 450.0 mm 1/2500 iso500
EricV
 TBLF's gear list:TBLF's gear list
Sony a7R V Sony FE 200-600 F5.6-6.3 Pentax *ist DS Sony 1.4x Teleconverter Sony FE 55mm F1.8 +4 more
Pentax K-1
DougOB
DougOB Veteran Member • Posts: 3,488
Re: Some Osprey sequences for comparison (Warning, Long...)
Thanks!
EricV
No comments on the photos, but my experience with the HD 1.4x TC is that it is very good with minimal loss (i.e., better than cropping) BUT demands a good starting lens (i.e., weaknesses will be amplified).
By all reports that I have seen it works well with the 150-450.
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR III Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 +37 more
ozdean
ozdean Forum Pro • Posts: 28,816
Eric these look good to me especially once you got the shutter up to 1/2000
I find 1/2000 is the starting point for bifs and disable SR of course.
When you go to crop mode on the K1 the pixel density is very similar to the K3III
IMO leave it in FF so you have a wider view of the bird then crop in.
I suppose the only question is , what was your keeper rate for the AF?
I have noticed results not as good re AF accuracy and speed when using the 1.4x wr on the 150-450; probably 15% less? Mind you have a very narrow window of view for bifs when on APSc which doesn't help.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
OP TBLF Senior Member • Posts: 1,549
Agreed
Agreed, though I haven't been all that fastidious about remembering to kill SR... oops.
Well, 16mp vs/24, that's at least a little noticeable, I would think, no? I was hoping so... but as I mentioned earlier, a lot of what's posted here is cropped WELL below micro 4/3rds, never mind APSC.
Agreed
Great question Dean. As long as I can pan accurately and fast enough against a clear sky background, the AF isn't horrid, but man oh man, let the subject get out of frame or away from the SEL9 group for a second and you have to totally feather the shutter part way with the SEL9 on the subject a few times to reacquire AF and by then it's usually too late, the moment has passed. OR... if the subject goes low against white caps and waves, or treed background, you have to make sure the subject focal point stays in play. Parallel is a better rate of course than coming at you.
Hmmm... If I were to be the spray and pray style shooter, I might be willing to settle for that 15% loss with the TC, but with the slow K-1 CPU & Mem, I fear it would be more than 15%, since I would be waiting on buffer to release too. The K-1 doesn't lend itself to spray and pray well for those reasons.
I've never been a wasteful person. My pop beat it into me (literally at times, owww...) He would take anything that broke and break it down into its components and shelve the nuts and bolts, motors, etc  for some future use. So it goes against my grain to buy something with the intent of not keeping it until it falls apart, but I might be best served by grabbing a K3III, new or even used or whatever, to play with and keep me interested until Pentax finally releases a K1 successor... then I can just peddle the K3III off and consider it a long-term rental. Heh.
Still on the fence... and still wishing we had a reasonably priced 200-600mm option available too.
EricV
JeremieB Senior Member • Posts: 2,067
Very nice pics ! I do think your pixel peeped results with K1 are better than mine with K3III, but I can't say why and there can be many reasons (first one : human failure ).
TBLF wrote:
Agreed
I agree too sort of, but I remember taking good photos of black swifts at less than 1/1000s. My theory is that they are so fast that if you keep them in the viewfinder, basically you move at same angular speed. If there's even a small difference, they're out of the viewfinder. Maybe in the end it's harder to use slow shutter speed with a slower bif, given also that they flap their wings faster most of the time. I don't know if it makes any sense.
Agreed
Well, sure, but that 200-600 would probably shine on the K3III too
Another question is, what kind of AF performance and parameters they will be able and willing to put in next FF. I often like to use the 12 FPS of the K3III, maybe less would be enough, but 12 is nice (I really mean 12, as sometimes you don't need to continuously refocus a scene or at least during a short time). It may be spray and pray, but sometimes it's just too hard to get the exact right moment (at least it is for me).
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
FrankPhilipGroehl
FrankPhilipGroehl Regular Member • Posts: 103
Almost all shots are attractive to look at, best for me: no.9, 16 and 22 . Despite the cropping you had to "fight" with heat flares (midday the more distance the more impact) plus highlights which you can reduce by setting the  EV to -0.3 or more. You can pull it up when post-processing. You used mostly what I consider the sweet spot for this high quality lens: f7.1 . Krgds, Frank
PS: As a proof that I'm not a "know-it-all" just have a look at my last year with Pentax, when I was trying different converters, lenses (Sigma 500/4.5 + the 150-450), the K1 and the K3-II - a selection of better shots achieved in 2016:
2016 Birds Selection  (last shots were then already made with the Oly M1-II)
 FrankPhilipGroehl's gear list:FrankPhilipGroehl's gear list
Pentax K-1 II OM-1 Pentax smc FA 50mm F1.4 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +14 more
