New to macro, tips for getting black background
Started 6 months ago | Questions
Dann-Oh Contributing Member • Posts: 894
Hey all,
Recently I started getting into macro.  I am currently using Olympus OMD EM1-3 camera body with either the 60mm F2.8 macro or the 30mm F3.5 macro lenses.  I also recently bought the Flashpoint MF12 for macro.  I am really enjoying the journey so far, I am still just working with single image files.  I have attempted Flowers and Mushroom photos (link the imgur albums)
I am wondering if you guys and gals could help me figure out an easy way to get a black background. I was able to get the black background on the flowers but I has to stop down to F16 (apparently that's too much for micro 4/3 sensors) and then I just basically dumped the black slider to the far left.  The flower images were nearly black without a flash so I think I am doing something right.
Is there a better way to get a black background?
Thanks for the tips I look forward to the journey.
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
richj20 Forum Pro • Posts: 10,181
Re: New to macro, tips for getting black background
dartymix1
dartymix1 Regular Member • Posts: 315
I sometimes use Lightroom masks, and select subject and invert, then  slide the exposure and black sliders.  I can use a brush to darken the rest.
Insert caption here. If you do not edit this text it will be automatically removed.
 dartymix1's gear list:dartymix1's gear list
Nikon D7500 Nikon AF Nikkor 85mm f/1.8D Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +3 more
BBbuilder467 Veteran Member • Posts: 7,057
Dann-Oh wrote:
Hey all,
When you reach macro image sizes with the micro 4/3, I don't think you can get the under-exposed background using flash like you can with flowers. It might be similar to the mushrooms, where you don't have enough open space behind the subject.
The simplest way in the field is use a colored card or fabric to isolate the subject. At 1:1, a US dime fills the frame, so it doesn't need to be very big.
ken_in_nh Senior Member • Posts: 2,399
Outdoors or indoors?  For indoor shooting, I bought a 16x20 or so painting canvas, added a base to it, and hung a black shirt over it.  Outdoors, I far, far prefer natural backgrounds.
OP Dann-Oh Contributing Member • Posts: 894
I have been doing a little bit of both.  I just got a piece of black foamcore to try to use in the field.
Landscape fabric works well to isolate subjects and is so light, it won't damage anything draping it over delicate stalks and flowers. It folds and compresses to take up no space at all. It's like a waterproof paper towel in texture.
OHH that's a good idea too.
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
Indoors:
Buy a few $ 1 tackboards from the Dollar store and light paint the flower in a dark area.
Apply the inverse square law and put the subject far enough in fron that it will be black as night and if your light  panting strays, it can be pulled down in post easily because  " 1/16" the light falls at this distance as it were compared to the subject.
You can uses flash and it works but it does not have the same feel and charm
The easiest way outside it to follow the same inverse square law and set the flash to illuminate the flower and little beyond. Yo get that jet black Nat Geo ant pic look like the above pix but a little more uniform.
If the goal is to isolate the flower - why not also use shallow DOF - it has great charm too.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
Rodger in Edmonton
Great idea BB - beats the heck out of pulling sliders and multiply modes etc
Quaecumque vera
Dik2 Junior Member • Posts: 45
Black Dress Velvet, and any white cloth. fold the black velvet so it's just a little bit larger than needed to fill the frame for each setup, and put it on a larger piece of white cloth.
The white will put some light on the back edges and separate the subject from the background.
 Dik2's gear list:Dik2's gear list
Canon EOS 6D Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS R5 +3 more
Interesting, Ill have to play with this.
c h u n k
c h u n k Senior Member • Posts: 2,042
Dann-Oh wrote:
Hey all,
Assuming you are thinking of images you see of flowers or mushrooms outside where the bg is dark to black?
Typically, with settings often used in macro, it completely drowns out all ambient light and the subject is lit with flash or, like I know is done with mushrooms a lot, the camera is mounted on a tripod (or tripod alternative) and the mushrooms are light painted with flashlights etc.
I suggest trying that. Set your fstop to f8 - f/10 and shutter speed at max sync which will make everything black, then light what ya want. Kind of funny because I go to lengths to light the background/avoid black backgrounds.
Some of my photos here: https://flic.kr/ps/2i6XL3
“You're off to Great Places! Today is your day! Your mountain is waiting, So... get on your way!” --Dr. Seuss
 c h u n k's gear list:c h u n k's gear list
Canon EOS 70D Canon 6D Mark II Canon EF 85mm F1.8 USM Canon EF 100mm f/2.8 Macro USM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +7 more
