Capture One iPad tethering
Started 7 months ago | Discussions
fujiframe
fujiframe Regular Member • Posts: 104
X-T4 tethered to M1 iPad Pro
Tethering is now available in the Capture One iPad app.
Tried it yesterday, tethering my X-T4 to an M1 iPad Pro. Raw image transfer was very quick. Great to be able to see images on a large screen (and full resolution) without bringing a laptop.
Prior to this update (released 20th Sept 2022), the app wasn't particularly useful to me as you couldn't change/view film simulations or tether. Still not sure a subscription model makes sense on top of the desktop license.
Film simulations can now be used/changed
 fujiframe's gear list:fujiframe's gear list
Fujifilm X-T4 Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR Fujifilm XF 23mm F1.4 R LM WR +1 more
rla1022 Contributing Member • Posts: 762
Re: Capture One iPad tethering
Glad they added the sims.
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
sshapiro Senior Member • Posts: 1,018
I am curious how the iPad version compares in function and performance to running desktop Capture One on a Microsoft Surface. The upcomfing Surface devices are supposed to have 12 generation Intel chips, so processor performance should be decent, but I expect the integrated graphics won't be a great solution for heavy editing.
eff56 Junior Member • Posts: 28
Is it wired tethering only, or is wireless available as well? If wired only, did you need to use any particular cable, or does it work with a regular USB-C cable?
 eff56's gear list:eff56's gear list
Fujifilm X-H1 Fujifilm X-Pro3 Voigtlander 40mm F1.4 Nokton Classic Fujifilm XF 56mm F1.2 R Fujifilm XF 23mm F2 R WR +2 more
Superscroll Forum Member • Posts: 89
Does the ipad version do all the same editing?
Do you need one of the new M chips for it to work reasonably fast?
 Superscroll's gear list:Superscroll's gear list
Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 35mm F2 R WR
fujiframe
OP fujiframe Regular Member • Posts: 104
According to Capture One “Wireless tethering is not available on any Fujifilm camera.”
I’ve tried a standard Apple USB-C cable and a cable from IKEA without issues.
FrameMyMind
FrameMyMind New Member • Posts: 14
How long did the battery of the iPad last? Is the iPad battery charged from the camera battery? Regards Peter
fujiframe
No, it's a much simpler version than the desktop app. There's no layers or masking (yet), it's mostly global adjustments.
I've only tested it on the M1 iPad so can't comment on the performance with older models
fujiframe
The camera is charged from the iPad rather than the other way around. I can't comment on the iPad battery performance as my tests haven't been over a prolonged period.
