Which 24-70 f2.8 for a 5D Mark II?
Started 7 months ago | Discussions
bill9991 Junior Member • Posts: 32
I am interested in getting a used 24-70 f2.8 (I had been thinking a lot about a 24-105 4, but think that the f2.8 would be helpful). I'd like to use it as a general walkaround lens as well as to do some stuff like indoor and outdoor weddings. I would primarily use it on a 5D Mark II that I recent bought used (as well as a 60D).
I'd say that about $800 or slightly more is the most I would like to pay, but would really like to get something for $600. Which lens would you recommend in this price point? I am open to considering Tamron and Sigma. And how does the Canon 24-70 Mark I compare to the Tamron G1 and to the Tamron G2? Is the Canon Mark II worth the extra money vs a Mark I? Any other things to consider?
Canon EOS 5D Mark II Panasonic Lumix DMC-G2
rmexpress22 Senior Member • Posts: 2,304
Re: Which 24-70 f2.8 for a 5D Mark II?
If I could help it, I would never ever use the 24-70mm Mark 1 with the 5D2 again. Yes, it's capable of perfectly good images but it was very hit and miss for me.
I never owned the Mark 2 of the lens, but it's definitely much sharper and consistent from what I've seen and it's what I would want where I go get an all-around lens.
I did own the 24-105mm Mark 1 and I really liked it on a 6D. The 6D had a poor AF system like the 5D2 except that the 6D has a really good center AF point. Either way, all AF points worked well with the 24-105mm.
Sigma and Tamron also make good lenses. I have a Tamron 35mm 1.4 that I really like. I don't know the exact model, but one of their newer ones. A Sigma 85mm 1.4 Art was my main lens for a long time. I also have a Sigma 14-24mm 2.8 that it very sharp wide open. I also have a Sigma 35mm 1.4 Art that was always wonky with extreme outer AF points, even with mirrorless. But I think the 35mm was one of the earlier designs. Newer Sigma glass seems to perform well. I considered the Sigma 24-70mm myself, but I usually work at 35mm or 85mm so I held off on that.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
gipper51 Veteran Member • Posts: 5,904
This is a tough decision at this price point, as all the options have some some limitations to consider.  Note that I have not shot with any of them, merely passing along what I've absorbed after spending too much time over the years perusing photo websites
Canon 24-70 Mk 1:  Known for high copy variation.  Not very durable, hence the high variation.  No stabilization.  No longer supported or serviceable by Canon.  If something happens, be prepared to possibly replace it.
Tamron G1:  Good lens overall.  Like all 3rd party lenses, AF consistency will be the biggest question.  Some have great luck, others not so much.  I have no idea how it will do on the 5D2.
Tamron G2:  Likely out of the budget, but you may get lucky on a deal.  Best choice overall IMO if you can find one in your price range.
Sigma 24-70:  Optically the weakest of the group.  Same potential AF issues.
For me personally, I'd look for a like new condition Tamron G1 out of this group.  That's probably closer to the $600 range.
Note that "AF issues" usually just means the lens requires more attention with AF micro adjustment for best results.  Personally I've had good results with 3rd party lenses, but they did always require some AF micro adjustment.  To be fair, most of my Canons do as well, just not as much.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
BlueRay2 Forum Pro • Posts: 14,816
i have the 24-70 f2.8 mk2 and as far as i know, it is by far better than mk1 in almost every aspect. mk2 is a brilliant lens, it is as sharp as most primes. i'd jump on it if i had the money for it. but it is up to you
The eye sees all but the mind shows us what we want. w, Shakespeare
hotdog321
hotdog321 Forum Pro • Posts: 21,141
While outside your budget, Canon's 24-70 f/2.8L II is likely the lens you want. I'm a pro and it is extremely sharp and resistant to flare, even when shooting into light sources. The focal lengths make it a real winner as a walk-around lens for mid-range shooting. I've used it for spot news and feature photography, but mainly for galas, parties and even office portraits.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
Original Canon 24-70/2.8 L is still very good.
The original Canon 24-70/2.8 L is still a very good lens.  Don't forget it replaced the 28-70/2.8 L and the 28-80/2.8-4 L.  It really is the third of 4 lenses.
From what I can see on the digital picture site, the version II has been marginally improved in the corners.  The first version is superior to the Tamrons.  It appears questionable whether the most expensive of the four Sigma versions is any better than the first Canon.
The Canon version II will be the best of all of them but is a marginal improvement over the original worth double the money, or more?
I would stick with Canon, and the original will perform very well.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
OP bill9991 Junior Member • Posts: 32
Thank you everyone - this is helpful!
MitchAlsup Veteran Member • Posts: 5,518
I have a 2003 <new> 24-70 F/2.8 L that works quite well on my 5Ds. If it puts up that good of an image on that camera, it will put up a good image on a 5D2.
Mitch
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
Re: Original Canon 24-70/2.8 L is still very good.
I fully agree with John. I have the Original Canon 24-70 f2.8. I bought it and used it on my 20D, 10D, 40D, 7D, but I mostly used it on my 5DII for many years. Was my workhorse lens when I did a lot of studio and event work (including a few lenses). I still have mine and do not plan on selling the lens. The used price does not equal the value of the lens to me. I have heard there are sample variations on the lens. Mine has been excellent. I had a Sigma 24-70 f2.8 EX lens before the Canon, but I never liked the lens. I actually gave it away. This was the older EX Sigma lens.
My only hesitation in recommending the lens is the lens is the age and not being able to get the lens serviced. But, it sounds like you have a limited budget. I can say personally I love the lens. If buying used you might want to look at KEH and MPB I believe both offer a six month warranty on their used lenses. I have bought several used lenses from MPB and all have been great.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
Arthur Stanley Jefferson Contributing Member • Posts: 809
The mk2 24-70 f2.8 is much, much better on my 5D mkiii
I had the mk 1 first, it’s tough, fairly sharp wide open, but it did not always focus accurately on the wide end at f2.8 -unless I zoomed in to focus at 70mm, locked focus then before pulled wide again to shoot. At f5.6, d.o.f. will hide this anomaly. In a studio setting I used manual focus and live view, for that use it was fine, but social photography required the focus lock technique in full af.
No such issues with the mk 2, it’s extremely sharp wide open and very accurate focussing from 24 to 70mm.
I set up my micro focus adjustments on both ends of all my zooms and check them every 6 months - it’s been rock solid.
As others have said, repairs on a mk1 might be hard to get done or more expensive due to parts supply.
It’s been so much easier for me with the mk2 24-70 for fast moving social photography, it’s a great lens.
 Arthur Stanley Jefferson's gear list:Arthur Stanley Jefferson's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM +4 more
