Dual sync cord question - Olympus E-M1 PT-EP11 housing with Inon Z240 strobes
Started 6 months ago | Questions
svreach New Member • Posts: 17
I am setting up a new (to me) Olympus E-M1 PT-EP11 housing with Inon Z240 strobes.
The strobes come with a dual sync cord to an Ikelite housing - a "Nikonos" type.
My question: Is there a way to use the dual sync cord directly with the PT-EP11 housing, or is there an adapter?
So far, I've only found an adapter for use of the Olympus fiber optic cord (PTCB-02) that connects to an Inon or Sea n Sea strobe type... I'm assuming if I go that route, I'll have to have 2 separate cords and an adaptor for each strobe.
It's my first time using 2 strobes and like to use manual settings (on the single one I've used up to now), so I'd obviously like to maintain a sync between the 2 strobes.
Thanks in advance for any answer to the adapter question and I'd welcome other advice on the use of Inon Z240's with the Olympus PT-EP11
~Michele
 svreach's gear list:svreach's gear list
Olympus Tough TG-4 Sony RX100 VII Olympus PEN E-PL2 Olympus E-M1 Olympus E-M1 II +7 more
Barmaglot_07 Contributing Member • Posts: 633
Re: Dual sync cord question - Olympus E-M1 PT-EP11 housing with Inon Z240 strobes
You need two fiber optic cables (Sea & Sea L-type to Inon D-type) and the Olympus clip-on flash (FL-LM2 if I'm not mistaken). You don't need any adapters; the Z-240 strobes have fiber optic connectors as well as electrical sync ports. You can't use the electric sync cord with this housing as it does not feature the appropriate bulkheads - it is set up only for optical triggering.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
OP svreach New Member • Posts: 17
Thank you Barmaglot_07! That is so very helpful.
I have the FL-LM2 clip on flash and intended to use it for a fiber optic cable.  It was just not easy to find the right connector to the Inon.
Much appreciated.
~Michele
