Best Camera for this?
Started 6 months ago | Questions
3ricc New Member • Posts: 1
Hello! I will be visiting lakes and the coral reefs in asia and would like to do some underwater videography and photography
I have been looking for a reasonably priced camera for this:
I want to take
- high quality macro shots of wildlife such as invertabrates underwater
- macro videography of them too
- additionally, I want a camera that can also do high quality regular zoom videos and pictures of the reef and lakes ect
Any recommendations?
Camrarat Regular Member • Posts: 349
Re: Best Camera for this?
Unless you want to go mirrorless/dslr in waterproof housing (which I do not recommend) the best option is most likely the TG6.
I have one and it is great, esp for underwater macro. A modest amount of zoom too.
kelpdiver Veteran Member • Posts: 5,564
So you need to fill in a bit of info here.
What is your diving experience?    How deep will you go?
Is this a backpacking type trip around Asia for many weeks?   A focused 1 or 2 week trip with lots of luggage?   Something else?
What does 'reasonably priced' mean to you?   And what does "high quality" mean?
For 15k, you can put together a great SLR system that does the best macro possible and also wide angle, shoot in 8k video.   It will also weigh over 30lbs in total.
A more compact APC or 4/3rds mirrorless setup cuts the weight in half, might cost in the upper single digits.
A good compact (fixed lens) setup might be 3-4k.
Unfortunately, overall there is a tradeoff between weight and quality, and price and quality.   There is also a pretty tall learning curve, so if you have no prior UW experience, a simpler setup will have better success on this trip.
I like the TG6 rec as a reasonable cheap try out, and it specializes in macro.   But it has a small sensor and limited manual control.  For a bit more, while still keeping weight down, the LX100 II is a compact with a massive 4/3rd sensor.    Especially good if you want to go casual on lighting/strobes.  But it's better at smallish stuff than true 2" macro subjects.
The Gopro is the 'hero' for lightweight and for easy video, but no one will argue it has anything but a casual shooter for macro.  It is the most backpacker friendly.   If you keep the depth limited, the TG6 can operate without a housing to 50ft, keeping the bulk down.
The used market is not what it once was, but there is potential to save there.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
My guess is you don't know much about the challenges here, and the limitations in both cost and lens choices, not to mention transport issues.
Probably the best camera for you is going to be a TG6.   It is particularly capable for macro shooting, and is one of the few options I could think of as at a reasonable cost.
Sony RX100, recent version, in a Nauticam housing would be another option, though you might need to add a wet lens for macro work.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Reefdiver Forum Member • Posts: 56
Unfortunately, you are likely to be disappointed. The high quality macro and wide angle pics you see and want to achieve take some diving skill, appropriate specialized gear and practice. The gear includes at least prosumer grade bodies and good lenses, underwater housings and, importantly, one or more strobes and a focus light. Then there is the post processing to remove back scatter, etc. But taking snapshot quality pics to enjoy your vacation is definitely achievable. GoPros are a popular, economical starting point. Moving beyond GoPros takes a significant commitment in time and money.
SubmersedShutter
SubmersedShutter New Member • Posts: 7
Indeed, UW photography is a true money pit and requires considerable skill set as mentioned by the previous respondents. My first question for you would be whether you intend to buy used or new gear.
In general a TG5/TG6 is a great start (even with new gear). A lack of shutter priority (which I consider more important than Aperature priority for underwater) and a weird JPEG red-balance are the downsides, but for a starter camera absolutely fine. For the Sony RX100 series, there are numerous options on the used markets for the camera, which is nice due to the larger sensor and generally more pleasure when in use above water. It is more fidgety and definitely not waterproof like the TG6 or SeaLife DC2000. Used housings are a risk that you need to determine for yourself, but there are several models on the market.
Keep in mind that for UW photography/videography you pretty much always need lighting, regardless of the day below snorkeling depth.
I just got back from Egypt where I tried using my 90mm macro on a fullframe camera for the first time. Despite a double flash and lights, most of my shots were out of focus, due to the extremely narrow depth of field (that you don't have to bother with smaller sensors). Furthermore, the rig weighs close to 7 kg above water and doesn't fit underneath most  crevices. Drift dives and long focal length macro will take lots of practice with buoyancy and handheld aiming of your rig (also sideways and being inverted).
Best of look and let us know what you ended up with.
 SubmersedShutter's gear list:SubmersedShutter's gear list
SeaLife DC2000 Sony a7 II Sony a7R II Sony FE 70-200 F4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +3 more
