Re: Stay with M43 or shift to FF for my hands?
2ndact scene1 wrote:
Kodachromelover wrote:
In 2013 I could shoot at ¼ second at 25 mm (50 mm equivalent in FF) with my E-P5. Now my hands are less stable: I have neither Parkinson's nor evident tremor at rest, but with the E-M1 Mk III with the 12-100/F4 Pro I can't go below 1/20 second.
I often shoot indoors, for example in Churches and Museums where tripods and monopods are forbidden, so I am very often at ISO 6400 and sometimes I would need to go higher. I don't mind high ISO noise, that's not the point; I am disappointed, however, for the loss of detail and dynamic range.
I'm asking you if a FF with a 24-200 (a must for me! I travel light) could improve my photos. Would the stabilization in the FF cameras do the job? Would a 24-200 lens have the same sharpness as Oly 12-200/F4 Pro?
Traveling light and FF are not something physically compatible in my experience.
For travel and also as a second camera for events I need something very light but capable of handling low light (I also like to photograph objects in museums and churches/temples/mosques). My solution is M4/3 gear with fast primes, by which I mean f/1.7 or possible f/1.4 lenses but not expensive and heavy f/1.2 lenses. So far, it is working OK but I am still making adjustments. I just got the PL 15mm f/1.7 for wide angle which has really impressed me. Ideally I would get the PL 42.5mm for something longer and use just two lenses.
I think if you are willing to compromise on lenses, and get one or two relatively fast primes for those museum and church interiors, you may have more success. Of course your needs may be different to mine. I typically don't use a telephoto when I travel, so this may not work for you entirely but maybe still something to think about.
Like you, some of my favorite subjects are small objects in glass cases and paintings (and details) in museums, as well as architectural details (gargoyles, frescoed ceilings, etc.).
For a long while, I’ve been using 2, sometimes 3 Voigtländer primes… 17.5mm, 42.5mm and adapted 75mm f1.5.
What I’ve discovered is that in order to get MORE Depth of Field, especially shooting small objects, I’m bumping the ISO and setting the aperture at f2.8, f4 and f5.6. For paintings, to avoid glare from overhead display lighting, I’m forced to step to the side and shoot at an angle. That means I need more DoF to get the entire thing in focus. Shooting from further away helps reduce glare, too. Resting the camera on my sling bag swung around in front helps with longer shutter speeds.
With glass cases, I've been using a folding rubber lens hood pressed against the glass.
The other problem is crowded galleries and struggling to compose with people in the way. I’ve been using longer lenses for that.
On the last few trips, I started using my 12-40mm. The zoom helps with crowds and to simplify composing. I just picked up a 35-100mm f2.8, so I’ll have more reach.
I do miss the Voigtländer image quality a bit, but I’m happy with the results.
Caravaggio: Judith and Holofernes (no tweaking)
