Re: Stay with M43 or shift to FF for my hands?
10
Kodachromelover wrote:
In 2013 I could shoot at ¼ second at 25 mm (50 mm equivalent in FF) with my E-P5. Now my hands are less stable: I have neither Parkinson's nor evident tremor at rest, but with the E-M1 Mk III with the 12-100/F4 Pro I can't go below 1/20 second.
I often shoot indoors, for example in Churches and Museums where tripods and monopods are forbidden, so I am very often at ISO 6400 and sometimes I would need to go higher. I don't mind high ISO noise, that's not the point; I am disappointed, however, for the loss of detail and dynamic range.
I'm asking you if a FF with a 24-200 (a must for me! I travel light) could improve my photos. Would the stabilization in the FF cameras do the job? Would a 24-200 lens have the same sharpness as Oly 12-200/F4 Pro?
Thanks!
L
I shoot Olympus (OM-1, E-M1iii, E-M5iii) and Nikon (Z6ii, Z7ii). The Olympus IBIS is much better than the Nikon IBIS. You would lose in a switch to Nikon.
Are you using the viewfinder? Getting the camera up against your face is critical for stability.
Have you analyzed how you hold the camera? With a lens as heavy as the 12-100, you need to use your left hand to support the lens. It's useful if your left hand is in contact with the camera body and your right hand when you shoot. If you like to shoot in portrait orientation, you should consider the control grip for improved stability.
Have you analyzed your stance? Try shooting towards your left shoulder, keep your left elbow directly under the camera and tucked into your body, and keep your right elbow tucked into your body as well.
Have you analyzed your breathing? Deep breath, exhale, shoot.
You might consider a chest support. It's a mini-monopod that is supported by a neck strap and never gets near the ground. Or small monopod inserted into a support that clips on your belt, with a neck strap so the monopod can't fall. I've used both. Usually, the fact that they don't his the floor is sufficient.
