Sugar crystals
Started 7 months ago | Discussions
3D Gunner Senior Member • Posts: 1,031
Sugar crystals
Sugar crystals (slightly melted) on a cake. (cross view)
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Re: Sugar crystals
Very good. I guess you had to be careful with the lighting. What size are these Sugar crystals.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
OP 3D Gunner Senior Member • Posts: 1,031
Re: Sugar crystals
Image is ~4mm wide, two LED light sources, 32 stacked images.
I will try to redo it with a different lens, a wider aperture and more stacked images.
Brian F Flint
Re: Sugar crystals
That's an incredible amount of magnification. I guess the stacking software outputs the stereo image.
Re: Sugar crystals
No. I made two sets of stacked images with a 2 cm stereoscopic base with the subject placed ~30 cm away from the sensor, so I used the classical method to get the 3D image.
The problem with macro, high magnification ratio stereoscopic images is a lot of work and fine tuning and the risk that something will go wrong and many hours of work will be wasted.🙂
Sugar crystals contaminated with coffee
A new cluster of sugar crystals contaminated with coffee
Stack of 56 images/eye.
