ISS at 1200mm f/8
Started 7 months ago | Discussions
Victor Engel Forum Pro • Posts: 20,968
ISS at 1200mm f/8
14
I had bad luck in an earlier try with IS turned on, so this time I turned IS off. This is hand-held.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,489
Re: ISS at 1200mm f/8
cool!
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
Very cool.  I have not looked for it.  Is it moving too quickly, like Skylab used too, to use a tripod?
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
OP Victor Engel Forum Pro • Posts: 20,968
I'm guessing it moves about the same speed as Skylab. The altitudes are similar, and gravity is about the same. I did use a tripod the first time, but my tripod is not friendly with pointing straight up, and this time, the altitude was 81 degrees, so I didn't even try.
Victor Engel
Dave
Dave Veteran Member • Posts: 6,231
Wow!
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
mdstocks New Member • Posts: 5
Victor
Did you use a red dot sight on the camera, or your eye to the viewfinder?
Did you have the focus pre - set at infinity and switched to manual?
Thank you,  Mark.
mdstocks wrote:
Victor
Thank you, Mark.
I tried one of those but found out I was more accurate by looking through the viewfinder. I use the rear to focus, and I did prefocus. This combination hunts quite a bit when what you're focusing on is essentially points of light. There should be a star-focus mode.
Victor Engel
Erick 21
Erick 21 Regular Member • Posts: 121
Amazing shot! Well done!
 Erick 21's gear list:Erick 21's gear list
Sony ZV-1 Canon EOS R Canon EF 15mm f/2.8 Fisheye Canon EF 85mm F1.8 USM Canon EF 100mm f/2.0 USM +7 more
