G1X 3 HOW NOT FIRE SO MANY SHOTS AT ONCE?
kevss Regular Member • Posts: 478
Just did first trip with camera. I cannot find  (or is there?); a setting so that when you press down only 1 shot is fired? Thanks.
Real problem as have many double shots did not want. thanks.
 kevss's gear list:kevss's gear list
Canon EOS 5D Mark II Canon EOS 5DS R Canon EOS Rebel T7i Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +4 more
Swerky Contributing Member • Posts: 793
Re: G1X 3 HOW NOT FIRE SO MANY SHOTS AT ONCE?
On your four way d-pad press up and you have single shooting as first option. Turn the wheel around the d-pad to get to it. Choose that.
Nothing to read here.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
OP kevss Regular Member • Posts: 478
Great Swerky thanks. I think if on trip the printed manual gave you hard to find, even in that?
You're welcome kevss  I didn't look in the manual if that's what you mean.
Was wondering if that is even in the printed manual.....
It should be. Never fully read a manual. If I bump into an unknown, I resort to the manual or mostly as a question on this forum.
Os S, curious if you have energy/ time  to see if in manual.. but not ok... thanks
Manual I love them usually by Canon, but this one seems bit hard to find stuff like that..
Jon_T
Jon_T Veteran Member • Posts: 6,393
kevss wrote:
... Os S, curious if you have energy/ time to see if in manual.. but not ok... thanks
With current digital cameras with all the settings, features, etc., along with some settings may disable certain settings; difficult to use the camera without reading the manual.
Even if you have 'other' cameras.
... Manual I love them usually by Canon, but this one seems bit hard to find stuff like that...
Generally just "thoroughly" reading/ understanding just the "Before Use" and "Basic Guide" needed to understanding camera controls, nomenclature used in the manual to be able to easily find things in the manual
In the PDF version "IF" you use the correct names/ terms for items, can easily find items by "simply" searching.
 Jon_T's gear list:Jon_T's gear list
Panasonic Lumix DMC-FZ200 Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot S110 Leica C +16 more
