Looking for a more versatile kit - Fuji x Switch to Sony
Started 7 months ago | Discussions
Night Pixel
Night Pixel Contributing Member • Posts: 976
Re: Looking for a more versatile kit - Fuji x Switch to Sony
Don't overlook the fantastic RX10M4. It has a great zoom range and excellent image quality for a "1-inch" sensor. Better than the Nikon P9000.
Check out the image galleries on FB RX10 user group for great examples.
**** REDACTED ****
 Night Pixel's gear list:Night Pixel's gear list
Sony RX10 IV Fujifilm X100V Fujifilm X-H2 Fujifilm XF 80mm F2.8 Macro Tamron 150-500mm F5-6.7 Di III VC VXD +4 more
Rod McD Veteran Member • Posts: 8,589
And-roid wrote:
Yes, I have had the A7IV and rate it very highly except,
1 The e-shutter is close to being unusable, the rolling shutter is very bad
2 In burst the lossless compressed reduces you to 5-6fps, compressed (lossy) can achieve 10fps in some situations but its 12 bit
3 The camera has very loud shutter sound in burst efcs/mechanical, annoying
4 No long shutter above 30secs without bulb,
5 No double exposure modes
6 No focus stacking
7 No rolling buffer, would be useless anyway as the e-shutter is bad
8 No 4k60 unless in crop
9 The evf definitely drops resolution in burst/c-af
10 There is an aa filter, but images are still fairly crisp
11 In timer modes, the af is locked at button push, can be an issue if people move, ie no real time eye-detection at that point of shot, 10 seconds people can move.
12 IBIS is still behind competitors
13 Noise on the high side for a FF sensor
14 AF boxes are still extraordinary large and box outline is very bold/thick, no pin-point af option
15 No top lcd info panel
16 Low light awb is just ok
I did extensive testing with raw files in DXO PL5 and found the iq remarkably similar to the X-S10 and X-T4 with little to no discernible difference in highlights/shadows etc. The sensor in the X-S10/X-T4 are the highest rated aps-c sensors ever by DXO, in case you aren't aware?
Thanks for this list of observations.  I have the XT4 and like it, but do ponder an A7R4.  I would only be interested in the A7R4A as a high res landscape stills shooter.  I suspect that  few of these observations would matter in that role.  It doesn't surprise me that the highlight/shadow performance offers little discernible improvement over the XT4 - it has exactly the same pixel pitch as the XT4.
I'm interested in your general comment that you found the IQ remarkably similar to the XT4.  The camera offers a linear increase in res of 50% (at the same pixel density because the sensor is larger).   In theory, once one starts printing beyond paper sizes where the paper's resolution limits detail, one should see improvement from the higher res sensor.  It should offer the same detail level when the print size is 50% larger.  Not so?
Were the lenses of comparable quality?  How big did you print ?  And how did the two cameras compare at different (large) sizes?  If there was little discernible difference, where do you think the 50% advantage in linear resolution was lost?
Thanks.  Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Zinch Senior Member • Posts: 1,122
6 No focus stacking
Thanks. Cheers, Rod
And-roid was talking about the A7IV, not the A7RIV. Blame Sony and their silly names
 Zinch's gear list:Zinch's gear list
Fujifilm X-T4 Voigtlander 35mm F1.2 Nokton Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 16-80mm F4 +3 more
zurubi Contributing Member • Posts: 868
I shoot both Sony and Fuji.
I had the Tamron 28-200 and sold it. Tried several copies and all had quite bad chromatic aberration. It's on ok lens, but not a fantastic lens like the fuji 16-55 or 70-300.
I wouldn't base a switch just on this lens.
 zurubi's gear list:zurubi's gear list
Sony a7R III Fujifilm X-T5 Fujifilm XF 10-24mm F4 R OIS Samyang 12mm F2.0 NCS CS Fujifilm 16-55mm F2.8R LM WR +6 more
And-roid
And-roid Senior Member • Posts: 3,208
The new Fuji 18-120 might be an interesting alternative, especially on the X-H2, the 18mm on the wide end should have been wider though!
a_c_skinner Forum Pro • Posts: 13,047
"I need a very versatile kit to be inspire me to actually go out and take pictures"
I doubt you will get that from a new camera.  You will play with it for a while but you will be left with the same level of inspiration.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Nielk Mike Senior Member • Posts: 1,480
Hi, as you can see from my gear list, I own the Sony a7c and the Tamron 28-200. In short, it is a combo that provides outstanding image qualtiy, for a zoom anyway. I take it when I need (or expect to need) the full range between WA and tele. The zoom is large, but not too large. Still, it is a kit that I don't enjoy carrying as much for its size and weight.
The a7c with the 28-60 kit zoom is even better, but obviously limited in focal lenght (which can be extended to 90mm by using crop-mode with good results). That kit is more to my liking.
In Fujiland, there is the 1545 - but I wasn't too happy with the IQ of my copies.
Despite the obvious advantages of the a7c in terms of AF (compared to my X-T3 or X-E3) and zoom lens selection, I do like shooting my Fuji cameras more. The small f2 lenses and an X-E3 are hard to beat when it comes to size and weight. I can put the 14f2.8 in one pocket, the 50f2 in the other, and use the 23f2 on the camera most of the time. If I expect to need atele, I use a small bag and pack the 55-200.
Especially with my family, but also at social events and for street photography, the small fuji footprint beats the a7c with the 28-200 by making you less obstrusive and visible.
Hi Zinch,
Thanks.  My mistake, and misplaced questions....  I've actually used my son's A7III, which is 24mpx, and (forgetting about the 2mpx difference compared to Fuji's 26mpx sensor) I wouldn't switch to FF for the same resolution level just to gain sensor size.
Cheers, Rod
