At last something to look forward to: the new 56/1.2 ;-)
Started 7 months ago | Discussions
deednets Forum Pro • Posts: 13,887
9
I have been using the 56/1.2 since March 2014. Used it for travel but also for portrait shoots.
Fuji X-T1, K-Road, Auckland March 2015
Fuji X-T1 Kumeu, Auckland, January 2015
Also used it for for some studio shoots:
X-T1, Auckland, August 2015
But also for some travel "stuff":
X-E2 Nelson, Arizona, April 2014
X-E2 Williams, Arizona, April 2015
The lens was slow regarding autofocus, but that didn't bother me. Enough. Shot slow when possible, but got a few shots out of focus where it mattered.
And then there was this MFD: 80 (or was it 85cm??) often a good enough reason to use the 35/1.4.
But whenever I went for some extended trips, the 56/1.2 would be in the bag:
X-Pro2, Yangon, Myanmar, October 2018
X-Pro2, Yangon, October 2018
X-Pro2, Inle Lake, Myanmar, October 2018
X-T3, Su Thep, Thailand, April 2019
So really looking forward to 50cm MFD
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Fujifilm X-E2 Fujifilm X-Pro2 Fujifilm X-T1 Fujifilm X-T3
Dinomalichela Regular Member • Posts: 123
Re: At last something to look forward to: the new 56/1.2 ;-)
How would shorter MFD improve your portraits? Could be useful for all other things non portraiture, no?
OP deednets Forum Pro • Posts: 13,887
I often go closer. Find that the 85 or whatever cms, to be reliable and not going borderline all the time, you need to vaccilate around a metre.
And 50cms would indeed make it useful for other stuff too. 11 aperture blades also interesting.
Deed
Deed
I suppose going closer to 50cm MFD would also enhance the blur in OOF zone, no? Also the bokeh has improved in the WR version with a complete disappearance of onion rings commonly seen in Ver 1. I am told chromatic aberrations are less prominent in newer version. Will we see noisy focusing motor yet again in WR version? No one mentioned a thing about that.
Deed
Indeed. I use the 35/1.4 close up and also the 50/2. This is a big one I think as you are correct: the background blur can be controlled even more.
