Spot meter technique
Started 7 months ago | Discussions
stevet1 Senior Member • Posts: 1,300
I just read about a spot metering technique that someone uses a lot.
The author said that in situations where he wants to emphasize a certain color in a scene that has multiple colors, e.g. green grass with blue mountains in the background, and he really wants to bring out the green,  he will spot meter on the green grass, lock the exposure, recompose, and take the shot.
That sounded like a worthwhile technique to try, as opposed to trying to matrix or evaluatively  metering the whole scene.
What do you think?
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Ray UK Contributing Member • Posts: 977
Re: Spot meter technique
Doesn't really make much sense, spot metering is about getting the right exposure for a small part of the whole scene not for adjusting colour.
Exposure metering is not colour sensitive and only relates to the amount of light being reflected from the subject, in effect it is giving you an exposure for a correct mid grey tone.
Dunlin Senior Member • Posts: 2,611
Steve, Spot Metering is one of those things I need to do more of.
Anyhow, this is all I can offer:
  1. Metering only affects exposure.
  2. If you want to emphasize greens, then either adjust your camera's color profile settings (for JPEGs) or adjust colour saturation in software (RAW).
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
OP stevet1 Senior Member • Posts: 1,300
I know that spot metering only meters about 2% in the center of the frame.
I think the exposure lock and hold is the key. I remember one time when I was trying to take a picture of a small yellow flower set in amongst a larger dark back ground of forest leaves. When I used evaluative metering, the camera metered the larger mass of background, and the yellow flower was washed out.
The flower itself was off to the side, and not in the center of the frame. If I had centered on the flower and spot metered off it, then locked the exposure, and recomposed the shot, it might have worked.
The key is holding that exposure lock. In my camera. the exposure lock only lasts for six seconds, but by using AI Servo and holding down the back button AF focus button, I can hold that exposure lock for as long as I want while I recompose. The little depth of field preview button on the bottom of your camera will do the same thing. The key is that you can't let go of the  button, or the timer starts kicking in. That's why I use Servo instead of One-Shot, and why I have assigned focusing and metering to separate buttons. The AF button focuses, but doesn't meter.
I don't know how well this would work with a wide expanse. If you meter off the bight blue sky, the darker foliage will turn out black, especially if there is a stark contrast between light and dark elements.
I need to experiment some.
Steve Thomas
No. I took a handful of pictures with this technique.
They suck.
I think I'll leave spot metering to creating silhouettes, or the rare occasion when I'm trying to get a small yellow flower surrounded by dark foliage.
Steve Thomas
They suck.
Steve Thomas
Matrix (sorry, I think that's the nikon term, I can't remember canon's) metering (the usual one) works fine 95% of the time, it's only for particular circumstances that spot metering is needed.
