Canon EOS 4000D and EF 50mm 1.8STM
Started 7 months ago | Questions
DarkoR New Member • Posts: 3
Hello,
I have Canon EOS 4000D and EF 50mm 1.8STM.
I noticed that pictures taken with f/1.8 to f/2.8 are out of focus when I'm focusing on focus dots with auto focus.
When I'm focusing with live preview focus is OK at whole range of f.
I found that my camera have 9 AF points (f/5.6 cross type at centre).
Does it means when I'm using f less than f/5.6 I will have issue with auto focus?
Canon EOS 4000D
stevet1 Senior Member • Posts: 1,300
Re: Canon EOS 4000D and EF 50mm 1.8STM
DarkoR wrote:
Hello,
DarkoR,
I have read that those wide aperture lenses are not at their best when wide open at 1.8 or 2.8, but I saw a picture the other day that was taken at 1.2 that was pretty good.
The thing is that at those wide open apertures, your depth of field is going to be pretty small. The specific thing you are focusing on will probably be in focus, but everything else will look blurry. The depth of field can be so small that one eye in a person's face will be focus, and the other eye won't be.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Aoi Usagi Veteran Member • Posts: 3,221
DarkoR wrote:
Hello,
If your camera and lens are having trouble achieving precise focus through the viewfinder, but not when in liveview, it could be the camera/lens combo will need some type of micro focus adjustment.  This is actually quite common among fast lenses (F1.8, etc).  Unfortunately, the 4000D does not have such an adjustment as Canon deemed it as a budget camera.  More expensive cameras have this adjustment in the Menu.  One option is to call Canon support and tell them.  They may ask you to send both the lens and camera to them so they can adjust them accordingly.  Of course, you will need to pay a fee.
Dunlin Senior Member • Posts: 2,611
Aoi Usagi wrote:
DarkoR wrote:
Hello,
What you say is correct.
But, it might be just as well to buy a new camera. Something like an EOS 30d or 40d would cost probably about the same as a repair/fix from canon, if such a thing is even possible (the 400d may not be supported by canon any more). A 40d (for example) would have similar specs to the 400d, but it would have AF microadjustment. The only downside (IMO) would be added weight.
There are a lot of folks on the other canon forum who love the 40d.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
I don't think the 40D, or any Canon xxD DSLR before that had AFMA.  It started with the 50D.  It was removed in the 60D and came back with the 70D.
The 4000D also has a higher megapixel count than the 30D, 40D, or 50D.
guinness2
guinness2 Veteran Member • Posts: 4,617
Try to use just the central AF point.
Post a sample including EXIF
Mind, that depth of field = things in focus, could be around 10cm deep space.
Among others, it depends on the distance; which you didn ‘t mention.
https://www.cambridgeincolour.com/tutorials/dof-calculator.html
http://www.dofmaster.com/dofjs.html
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
guinness2
AF point f/5.6 means, if you have less light, for example f/16, it could have focusing problems. 2.8 , even better than 5.6
Btw, not sure what you mean by “less than f/5.6”
Canon EOS Rebel SL3
Sorry, my mistake.
Still, a 50d is only about £15 more.
Megapixels aren't everything.
I'm starting to feel like the bad guy who only suggests buying new gear. I'll shut up now.
OP DarkoR New Member • Posts: 3
I mean less than f/5.6 are f/1.8 , f/2.0 ....
In description of camera's specifications, I've found that more expensive cameras like EOS 850D has:
"Via optical viewfinder:
45 cross-type AF points
(45 f/5.6 cross-type AF points, 27 f/8 points (9 cross-type), centre point is f/2.8 and f/5.6 dual cross-type)"
and for EOS 4000D:
9 AF points (f/5.6 cross type at centre)"
As we can see 850D has f/2.8 centre point, and 4000D has only f/5.6.
My question is what is difference between f/2.8 and f/5.6 points?
and for EOS 4000D:
If an AF point is f/5.6, then it won't work with lenses slower than that aperture, eg. f/8.
On my 7D, the AF centre point is dual-cross type at f/2.8. I think that's what the part about the 850d means.
The 850D uses Dual Pixel AF (in liveview), which allows the camera to focus at f/8 in live view.
