Fujifilm X-T4 shutter button sadness
Started 7 months ago | Discussions
John Maguire New Member • Posts: 16
I bought a used X-T4 about 3 months ago. It has 8,500 actuations on the shutter (7,000 of which I put on it) and worked great until today.
I have been using a soft release button since I bought it. I liked it because I have small hands / fingers and it reduced reach in a meaningful way. Earlier this month I read that this can cause issues with some cameras but left it on. The shutter button seemed to essentially spontaneously fail in between shots today.
There is no tactile response between unpressed and firing the shutter. It is just a mushy button which starts to focus somewhere between feathered and bottomed out and immediately takes a shot if focus is found. (AF-C, focus priority on, w/ AF-C set to focus w/ shutter.)
Anyone else have shutter issues on the X-T4? Is there any quick fix I can try or am I going to have to pay to get this fixed? Everything I've read so far says that Fujifilm will replace the entire top plate.
 John Maguire's gear list:John Maguire's gear list
Ricoh GR III Ricoh GR IIIx Fujifilm X-T4 Fujifilm X-T5 Fujifilm XF 35mm F1.4 R +9 more
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Re: Fujifilm X-T4 shutter button sadness
8500 is nothing.
I am an X-T4 owner, too, but my shutter button is good. I often work with half pressing it before releasing the shutter.
However, I've occasionally read about that sort of problem here in ther forum. Here's an example, Wobbly power/shutter button on the X-T4.
Not sure about the way of repair.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Papa48
Papa48 Senior Member • Posts: 4,861
I’d describe my X-T4 shutter release touch as soft and slightly loose. I’ve subsequently had to learn to be very light on the half-press, or it goes too far and the shutter is unintentionally tripped. Sometime in the future I anticipate needing a service. It’s out of warranty.
 Papa48's gear list:Papa48's gear list
Sony Cyber-shot DSC-RX10
rla1022 Contributing Member • Posts: 762
The problem I am facing is I guess I don’t know how the shutter is supposed to feel and what defines a tactile response. I had an Xt-2 that had no actual stoping point and it felt like a traditional PASM camera. I got an Xpro 3 and it has a stop on half press and then a forced push to take the shot. I thought maybe my soft release broke something. I just got a backup Fuji Xe-4 and the shutter does the same thing as my X-Pro 3.
My point is that it may not be broken
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
OP John Maguire New Member • Posts: 16
Mine's definitely broken. I fiddled around with it some more and sometimes it's not even firing the shutter.
I sent it in to Photo Tech Repair Service, an authorized repair technication listed on Fujifilm's website as they gave me the best estimate between them, Fujifilm North America, and an unauthorized repair shop in my city. Fujifilm NA refused to give me any kind of phone estimate, even when I asked "what would it cost to replace the entire top plate?"
Hopefully the repair doesn't take too long.
Rightsaidfred wrote:
8500 is nothing.
I know... what a bummer.
My best guess at how I broke it: I was trying something akin to spin zooming using the focus dial (not in MF mode) for creative effect... I'm guessing that the soft release button acted as a lever in the wrong direction while spinning the camera.
This is one of the very last photos I took before I noticed the issue.
Clive99 Senior Member • Posts: 1,389
Do you mind sharing how much the quote was. My XT3 has a sticky shutter button from some salt water spray. Still works but sometimes sticks and requires more force. Just what a rough idea what the cost will be.
thx
 Clive99's gear list:Clive99's gear list
Fujifilm XF10 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 18mm F2 R Samyang 8mm F2.8 UMC Fisheye +16 more
thx
The repair shop in my city said something like $400-500 for the part alone.
Photo Tech said something like $250-350 for the part, and with labor it'd probably end up around $400-500.
I'll update the thread once they receive the camera and give me a proper quote or invoice.
thx
$332 parts + $145 labor + $30 return shipping = $507
This doesn't include shipping to them (~$20 insured.)
Papa48
John Maguire wrote:
thx
Ouch!
