Star ghosting/flaring or light bouncing?
Started 7 months ago | Questions
Karlson-B
Karlson-B New Member • Posts: 13
Hi,
yesterday night I made some test shootings at the night sky and discovered a phenomenon which I can’t explain and hardly name correctly. I would call it „multiple existence“:
Jupiter, X-T4, Samyang 135mm, 1s, f2, ISO2500
it only appears on the bright Jupiter, not on fainter stars.
what I tested is, that it’s not dependent on
  • Camera (happened on X-T4 and X-T2 as well)
  • lens (happened on adapted Nikkor AF-S 80-200 f2.8 as well)
  • ISO
  • f-stop
  • shutter type
  • exposure time
Cameras where in fully manual, no IS/NR, uncompressed RAW, triggered with 2s selftimer.
As far as I know X-Tx cams are quite suited for astro photography - so I‘m wondering what causes my issue.
Any ideas?
thanks,
Greg
 Karlson-B's gear list:Karlson-B's gear list
Fujifilm FinePix S2 Pro Nikon D2X Nikon D3 Fujifilm X-T2 Fujifilm X-T4 +13 more
Fujifilm X-T2 Fujifilm X-T4 Nikon AF-Nikkor 80-200mm f/2.8D ED Samyang 135mm F2.0
Erik Baumgartner Senior Member • Posts: 6,894
Re: Star ghosting/flaring or light bouncing?
Moons?
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
wawatson Forum Member • Posts: 97
Erik Baumgartner wrote:
Moons?
Agree with that ...
using stellarium-web.org, the moons were in that configuration on 1st September when viewed from near Northampton, UK.
From the left, the moons are Callisto, Europa, IO and (on the right) Ganymede.
Well done
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Karlson-B wrote:
Hi,
  • ISO
  • f-stop
  • shutter type
  • exposure time
Any ideas?
thanks,
Greg
As others have pointed out, there's nothing wrong with your shot (other than the fact that it's a bit overexposed).  You're looking at Jupiter plus some of its moons.  Try shorter exposures next time and you might start to see a bit of detail and color within the disc of the planet.
So... no issue whatsoever.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
Karlson-B
OP Karlson-B New Member • Posts: 13
Karlson-B
Thanks @Jerry-astro,
good points with overexposure.
i was so confused about the „issue“ that I wanted to get it as clearly as possible, image quality was no concern anymore.
So I guess that my gear is quite capable in resolving the Jupiter moons
Clear skies
Greg
Pocket Lint Senior Member • Posts: 2,540
The flaring you see coming from Jupiter looks like diffraction. Jupiter is the closest, largest and brightest object in the photo. The other point sources of light are it’s moons, which Jupiter has a constellation of over 60 moons if I recall correctly.
Im no astrophotography buff, but I do love observing the night sky and learning about astronomy and astro physics
 Pocket Lint's gear list:Pocket Lint's gear list
Canon EOS 5D Mark IV Fujifilm X-Pro3 Canon EF 50mm f/1.2L USM Canon EF 100-400mm F4.5-5.6L IS II Fujifilm XF 23mm F2 R WR +5 more
