Jouko
Re: My experience after using E-M1 Mark II
gursharan-info wrote:
Three months ago, I bought E-M1 Mark II camera and I have used it extensively for bird photography. Initially, I used Panasonic 100-300 II and now I have settled for PL 100-400. As a combo deal, I also got Kenko 16mm and 10mm extension tubes. This setup has served me well and is giving me more than satisfactory results.
Recently I've added Oly 60mm macro, Godox V860IIo to my arsenal and started macro photography with the setup. Following are my observations so far about my setups. You can add, contradict if you had different observations, and correct me If I am wrong.
Birds and other wildlife:
- For birds, I am mostly using 250-400mm range only. Relying on the Lens OIS has proven more effective than IBIS. The settings I use are posted here .
- Using extension tubes with 100-400 has given me very good results on butterflies, blister beetles, and other bigger macro subjects.
- One issue I have is that while using C-AF my keeper rate (2~3 / 10) is not very good for distant birds or BIF shots. I tend to prepare well for this and have got at least one shot of the subject I see and think of. But I do long for a keeper rate like people have reported here with Oly 100-400. If I get a used one in my country, I will switch for sure. The new one here retails for about $1800.
The keeper rate... 2-3 out from 10 is quite good. Of course it depends on how "easy" shots you are taking, and what kind of limits you have for a "good" shot. 100-400mm lens is never the simplest lens to handle and for sharpness there are many factors to handle - holding and technique, shutter speeds, distance, breathing and other shaking, atmosphere... Using a tripod or handheld, IS vs OIS vs both vs none... And then the bird moves... As for the differences between Oly and Pana 100-400: there may be some, but mostly irrelevant if you have a good copy in your hand.
So, if you want more keepers, just keep shooting! There is the delete-button for those no-keepers. I should use it more...
Macro Pictures:
- I had a couple of photo walks for the macro in the last 2 weeks. I am really impressed with what I could achieve with this tiny lens, a flash, and a proper diffuser.
- The focusing capability is slow at times, and I have missed many bugs during the focus time. Maybe practice will make me better.
- Using the viewfinder with setup seems difficult and I relied on the live view screen more while simultaneously tracking the bug with naked eyes while I am setting up the frame.
- For smaller bugs, I tried using the extension tubes with a 60mm lens. While it gives good results with flash but there is some light loss observed. Also, the focus gets wafer-thin with tubes. So, when I was holding a leaf in one hand and a camera with a big flash in another hand, many of my subjects were slightly out of focus because of some movement.
- There are times when I get a skittish subject like grasshoppers, I had to remove extension tubes because bringing them into focus plane scared them. Also with multiple times removal of tubes, the lock string of my 10mm tube is broken. I think a quickly removable diopter like DCR 250 can help me better than tubes here. Let me know your views here.
I suppose the 60mm is best as is, going down to 1:1. Also focus stacking can be used. I don't have that lens, still use the old 50mm f2 macro, but but... Both can be used, the tubes and/or the achromatic macro lens. Raynox versions sem to be very popular.
I use tubes if needed, but you loose some light with the tubes - it's just physics. The longer tube the less light. Macro filters work a bit different way, so the loss is less. Which is better IQ wise, depends on the combination.
And you are right, the DOF is thin with extreme magnifications. You may even ask which DOF. But with focus stacking you'll get some.
BTW, you can also use the tubes with the 100-400...
The flash... Godox V860IIo is quite large. For macro with 60mm lens I would get a smaller one, either a dedicated macro version or something like Godox TT350 - or Oly FL 600R or older FL36 (R). They are easier to work with, and have enough power for close-ups. The 860 works fine with the 100-400 and birds, if you need some fill light.
For now, I am separating my targets, i.e. if I decide on macro on a garden, or forest area walks, I will do that only. Removing the diffuser setup and mounting a zoom lens in between can be cumbersome, not to mention the moments/clicks I would miss while doing that. Will add a second faster body like E-M1x for birding when I can afford one.
Maybe I should do that too...
Have a nice day!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
