Canon bans Viltrox lens
Started 7 months ago | Discussions
NanoCam Junior Member • Posts: 25
I just read that Canon has forbidden Viltrox from producing a lens (85/1.8 and maybe others?) in Canon RF mount. In this case who cares? There are lots of 85mm lenses including Canons’ great 85/2 macro.
I also know there has been an astounding Samyang/Rokinon 10mm f3.5 rectilinear 130° lens around since 2018 available In Canon EF mount. Now I ask what Canon EF user really needs it with the 11-24 zoom?
The 10mm f3.5 remains unavailable in Nikon F mount. So something similar is going on with Nikon. No one including B&H knows and the manufacturer wont answer. Nikon makes no 10 mm in F or Z mount, so it is much needed for surreal fx shooters. One can get a Voigtlander 10mm clumsily manually adapted to the Z, Canon RF, and Voigtlander makes it for Sony and Leica. but 14mm remains the Nikon wide limit.
I’ve been an ultrawide user since Nikons’ glory days 15mm f5.6, so for me 14mm is not new
Why are they preventing this?
Whether Nikon or Samyang/ Rokinon, they’re only hurting themselves!
I’m sick and tired of these limitations! This is one important reason if & when I decide to go to mirrorless I will probably skip Nikon and go to Canon which is more innovative and likely to produce more new lenses like a new smaller 11-24 or wider. And Sony already makes a 12-24/2.8.
sybersitizen Forum Pro • Posts: 24,305
Re: Canon bans Viltrox lens
I assume you read this:
https://www.dpreview.com/news/3875526045/viltrox-representative-reports-canon-told-them-to-stop-selling-all-rf-mount-products
I don't think it's possible for camera companies to 'ban' an entity from making lenses. Nothing restricts anyone from making products that are compatible with the physical mounts.
Camera companies can withhold proprietary communication protocol information from entities that don't pay a licensing fee, but that's something different. Sigma was notorious for failing to properly license the communication protocols for the A-mount system, but just reverse-engineered them instead (which led to a number of compatibility issues).
As far as I know, the question of the legality of Sigma's reverse-engineering was never tested. If Viltrox is now doing what Sigma did, Canon may be inviting a legal battle that the much smaller company can't afford to fight.
MitchAlsup Veteran Member • Posts: 5,518
You see, there are these things called patents.
You get one, and you have exclusive used of that material for "a while"
I am sure one or more parts of RF are patented. Thus Canon has say on who can mount to what.
Just one more reason to stay away from mirrorless (where the patents won't run out for decades.)
The situation is different between Company secret (communications protocol) and patented. Company secret can be reverse engineered (to the 98% level). But patents are granted exclusive use to assigned company.
Mitch
ulrichsd
ulrichsd Regular Member • Posts: 107
From what I've read, it sounds like they are issuing cease and desist to all 3rd party lens manufacturers as Tamron has also announced they will not be releasing RF mount lenses.
 ulrichsd's gear list:ulrichsd's gear list
Nikon Z6 GoPro Hero8 Black Tamron 100-400mm F4.5-6.3 Nikon Z 24-70mm F4 Nikon Z 14-30mm F4 +3 more
bodeswell Senior Member • Posts: 1,378
What makes you so sure they have patents on the physical mount? Canon hasn’t taken action against third party EF to RF adapters. What patentable inventions might there be in the physical mount itself? It seems more likely that they are not allowing use of their RF protocols. They have taken no action against third party EF mount lenses.
You will have to stay away from a lot of things if you are waiting for patents to expire, not just mirrorless cameras.
 bodeswell's gear list:bodeswell's gear list
Canon EOS R Canon EOS R5 Canon EOS R7 Canon EF 135mm F2L USM Canon EF 200mm f/2.8L II USM +4 more
Scott Larson Veteran Member • Posts: 7,505
I'd love to know what "new" and "unique" technology Canon has discovered for the RF mount.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
Yes. Have you read the patent application for Canon's RF mount? I have. It's focused on the specific communication protocols rather than the physical design of the mount, which is just a minor variation of the twist/lock method used throughout the industry.
The DPR article says this, focusing entirely on the electronic and communication factors:
It’s unclear whether third-party lens manufacturers using electronic connections with Canon’s RF-mount alone is the issue or whether it’s the code, reverse-engineered or otherwise, enabling AF that’s causing the issue.
As it stands, with Viltrox’s 85mm F1.8 AF lens out of the discussion, only manual RF-mount lenses remain available to purchase from third-party manufacturers (barring second-hand sales elsewhere). This alone suggests some kind of limitation with either the code required to power the AF functionality inside the lenses or an issue with using the electrical contacts at all.
What's the number of this patent? I tried searching but I only found their patents for RF lenses.
Igor Sotelo Contributing Member • Posts: 923
Sigma with their Art series made Canon lose a lot of revenue in their EF system. They aren’t probably worried about Viltrox, but about Zeiss, Sigma, Tamron and Voigtlander, that can significantly hurt the sales of Canon RF lenses.
I think this will reduce Canon body sales, for people that could afford the body, but not also the exorbitant price of high quality Canon RF lenses.
Sony opted to open their FE system to third party manufacturers, so those manufacturers AF works at the same level as native lenses. It doesn’t seem to have significantly hurt Sony’s sales, the company is confident they can make better lenses to justify the premium. And it helped Sony gain momentum when their lens catalog was reduced.
Nikon already has Voigtlander making lenses for the Z-system. Not sure if reverse engineering will be required for AF lenses, potentially reducing their performance.
 Igor Sotelo's gear list:Igor Sotelo's gear list
Nikon D800 Canon EOS 6D Nikon Df Canon EOS 5DS Sony a7R II +35 more
Canon has always made a range of bodies as well as a range of lenses, and with RF the are making affordable high quality lenses at price points they previously didn’t occupy. In short, they are competing. Seems to be working so far, even if some folks get all teary eyed about Sigma primes.
Looks to some like Sony has lost momentum.
I’ll bet Sigma and Tamron are pretty protective of their own intellectual property.
But it’s Canon whining and not competing, about Viltrox making lenses for the RF mount.
It depends much what you call quality. L lenses yes are quality, you have admit Art lenses are quality too, non-L lenses aren’t in the same league, optically and how are they built.
One weakness that I see in Canon’s line up, is that if you want IBIS and full frame 4K, Canon will ask for that at least $2.5K (R6 with slight 4K crop) which is a bit steep. Personally couldn’t care less about video, however IBIS is important. But many do also shot video. On the other hand, you can get IBIS and full frame 4K from Sony and Nikon for much less.
Native lenses are equally expensive, but with Sony you have more options, like let’s say the Tamron 70-180mm 2.8, the Sigma Art 40mm 1.4, the Zeiss Batís APO Sonnar 2.8/135 or the Voigtlander Macro APO Lanthar 110mm 2.5.
Not sure what sales figures show, though.
I think the laws in Japan allow a Japanese company to reverse engineer for designing AF lenses, but that isn’t allowed for foreign companies.
Sony’s FE-system is open, unlike Canon or Nikon systems that have to be reverse engineered, which affects AF performance.
They aren't "whining". Whining would be complaining but not doing anything about the infringement. Canon is taking legal action to stop the alleged infringement. That is a matter of ensuring that competition is fair. I'll bet Viltrox would protect its own intellectual property.
Canon is also competing by producing what I am sure they think is a better but still moderately priced RF 85mm f/1.8 half macro lens that works perfectly on all RF mount cameras.
That doesn't mean they aren't quality lenses. By the way, some might even suggest that the differences between L and non-L lenses are easily exaggerated.
Reverse engineering is generally legal so long as it does not infringe by, say, copying or directly using someone else's intellectual property. Perhaps Canon has, inadvertently of course, made it hard to reverse engineer the RF protocol be adding so many new things to it (IBIS, fancy AF modes). But end users benefit from those new features.
People may need to decide what they really want.
My guess is that the people at Canon believe otherwise.
Mitch
Rock and Rollei Senior Member • Posts: 2,916
Canon haven't had any problems selling RF mount cameras over the last few years, and they would much  rather sell them to people who will buy their lenses rather than Sigma'a. It's been a corporate goal for many years to maximise Canon lenses sold per camera, and they've gor a new tool to do it. Canon aren't Sony and they aren't Nikon, and anyone who expects them to behave in the same way as Sony or Nikon simply doesn't understand the company. They didn't get to where they are by copying other companies, but by doing things a bit differently.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Canon purposely designed their EX 580 flash to jam the frequency used by Pocket Wizards, the most popular third party radio trigger at the time. That told me what Canon thought about third party products.
More likely Canon simply ignores third party products when developing its own. Canon does not ask those third parties to develop product, and they don’t share their income or their plans with Canon.
Japan Patent Application 2018-084713, as noted here:
https://www.canonnews.com/canon-patent-application-the-first-sniff-of-a-new-mount-for-canon
Great, they patented the size of a hole and bunch of connectors. Innovation!
No, the EX 580 was shown to transmit a jamming signal right at the frequency that Pocket Wizards used. I sent my two EX 580s to another third party for a simple and inexpensive modification which stopped it so I wouldn't have to use Pocket Wizard's EMF socks on them.
Canon clearly knows a lot about third party products.
I did not speak to what Canon might know. I said that when they design their own products the spend no time worrying about how their design decisions might affect third party products. They ignore that. As they should.
