EOS R3 Self-timer with multi shot, no? How?
Yana2
Yana2 Forum Member • Posts: 85
Got the EOS R3 near a month, I just make a group selfie with the 10sec timer with my colleague, but when I change the drive mode to self-timer, I can't found the timer icon that I can set how many shot on timer.
I have this functions, one the EOS 700D, A7III, EOS M etc, but no at R3, Am I missing some setting?
From EOS 700D
EOS R3 online manual about Drive Mode:
https://cam.start.canon/hy/C010/manual/html/UG-04_AF-Drive_0100.html
Just 10 / 2 Seconds timer
On EOS R3 I can have Interval timer on Menu 1-7, but that timer not working like self timer:
https://cam.start.canon/hy/C010/manual/html/UG-03_Shooting-1_0290.html
Interval timer on EOS R3
Should I need plug the Timer Remote TC-80N3 to make it work!? oh my....
 Yana2's gear list:Yana2's gear list
Sony a1 Canon EOS R3 Canon EF 15mm f/2.8 Fisheye Canon EF 28-300mm f/3.5-5.6L IS USM Canon EF 180mm f/3.5L Macro USM +12 more
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i) Canon EOS R3
Yana2
OP Yana2 Forum Member • Posts: 85
Re: EOS R3 Self-timer with multi shot, no? How?
Still can't found any way on Multiple shot with self-timer, just work around with mobile phone Bluetooth remote control.
drsnoopy Senior Member • Posts: 1,216
Hi - that option is present on the RP, but not on the R5. I have no idea why!
However here’s a workaround. Use exposure bracketing with a 10sec delay. You can set 2,3,5 or 7 images. If you chose 3, you could set your brackets at -1/3, 0, and +1/3 stops. This would be a negligible difference and easily fixable in post to give identical exposure.
Hope that helps.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
apersson850 Senior Member • Posts: 2,076
The "number of shots when the self timer expired" is a feature Canon has included on some of the low level cameras. They probably think that their "real" cameras are used by somebody holding them.
Sure you can use the interval timer. Just delete the first/first few images, and then it will take photos at regular intervals.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
Falxon
Falxon Regular Member • Posts: 338
+1 on the interval timer option.  I just tried this on my R3 and it works beautifully.  Just a quick note that I'd recommend setting a manual exposure, as you don't want it shifting exposure on you due to something around you changing.
 Falxon's gear list:Falxon's gear list
Canon EOS 7D Mark II Canon EOS R3 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 500mm f/4.0L IS II USM +13 more
Yana2
Hope that helps.
Bracketing, not bad idea.
MichaelFrederickPhoto
MichaelFrederickPhoto Contributing Member • Posts: 638
Another frustrating is not being able to use the interval shot using the Canon remote app.
I would need the app to set the focus as I am find using Continuous AF isn’t hitting accurately enough at a distance.
https://www.instagram.com/michaelfrederickphotography/
https://www.flickr.com/photos/159695193@N02/albums
Canon R6, Canon 16-35 F4, Sigma 40mm 1.4, Sigma 105 1.4, Canon RF100mm macro, and Tamron G2 70-200 2.8. Fuji X100v
