ISO not changing on auto iso
Started 7 months ago | Discussions
mikey201 Regular Member • Posts: 195
im using the Fuji xt4 with the 16-55mm f2.8
i just set up Auto iso. 1 2 or 3, no matter what iso i set for maximum iso it always stays on it..for example i set auto1 to   max sensitivity 3200
when i bring the dial all the way to the right to ISOA1 it just stays on 3200 no matter the light  inside or outside  shutter will adjust but thats it
 mikey201's gear list:mikey201's gear list
Sony Cyber-shot DSC-HX50V Sony RX100 IV Panasonic G85 Samsung Galaxy Note
Erik Baumgartner Senior Member • Posts: 6,893
Re: ISO not changing on auto iso
5
The camera will always display the preset’s maximum ISO setting with Auto-ISO on. With SHUTTER AE enabled, half-pressing the shutter button (or locking the exposure) will display the actual shooting ISO.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP mikey201 Regular Member • Posts: 195
No that still doesn't do anything. Still shows the maximum iso. When I snap a pic it's way overblown. Even if I go into a light setting it doesn't change
MrKazador31
MrKazador31 Regular Member • Posts: 174
Can you post a photo with the EXIF data intact?
 MrKazador31's gear list:MrKazador31's gear list
Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 80mm F2.8 Macro +3 more
What are all your preset settings (min SS, min ISO, max ISO?
Is your exposure compensation set at 0?
Are both  your ISO and SS dials set to “A”?
Can you post a pic of your rear screen and top dials in shooting mode?
nightowlnz
nightowlnz Contributing Member • Posts: 518
Also what metering mode (photometry) are you set to?
 nightowlnz's gear list:nightowlnz's gear list
Fujifilm X-T4 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
