Question about digital converter in x100v
Started 7 months ago | Discussions
0ursisthefury Regular Member • Posts: 262
Hey just want to know if there is any loss in quality using the digital teleconverter on the x100v. the range can change from 50mm and 70mm. I can't find the pros and cons of this anywhere
Fujifilm FinePix X100 Fujifilm X10 Leica X1
Erik Baumgartner Senior Member • Posts: 6,894
Re: Question about digital converter in x100v
The camera is cropping the original image to the desired field of view and (for jpegs) upscaling the image back to the original pixel dimensions. There is of course a loss of resolution relative to using the entire sensor with an optical teleconverter (or with no TC at all), but the results are typically very good nonetheless.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
aChanceEncounter Contributing Member • Posts: 846
I do use this occasionally - to help with composition framing when anticipating a crop
perfectly acceptable for small images
Paul
