X100V Help! SS and ISO dials not matching up with in-camera settings
Started 8 months ago | Discussions
DreadAlert New Member • Posts: 18
Hey everyone. Been using my X100V on holiday, handed it to my girlfriend and she's somehow changed some settings and doesn't know how. I can't figure out how to fix the issue lol so here I am.
I was shooting with SS and ISO on AUTO, and only controlling Aperture with the front dial - aperture priority is how I shoot most of the time.
She hands back the camera and now, even though the SS is on A, it's stuck at 1/2000SS. If I move the SS dial to 4000, the shutter speed goes to 1/250. One more click, down to 2000, gives me 1/15, and then some other ridiculously slow speeds until it's just bulb.
ISO is the same. A has me stuck at 250 ISO. 160 gives me 320, 200 gives me 400, etc.
Everything is weirdly off and nothing changes when on A like it should.
Have tried battery in/out, tried going to user settings and resetting both options .. I'm lost.
Anyone got any ideas? - also I have a video showing the problem, will share in a reply to this thread if I can get it working.
Thanks!
Fujifilm FinePix X100 Fujifilm X10 Leica X1
OP DreadAlert New Member • Posts: 18
Re: X100V Help! SS and ISO dials not matching up with in-camera settings
https://youtu.be/9BPwq_XWvvw
Video of the problem
For some reason the camera appears to be stuck in shutter priority, despite all dials being on AUTO.
Does this help at all?
Morris0
Morris0 Forum Pro • Posts: 32,181
I'm sorry to learn this.  Backup your settings.  Do a reset to factory.  If this dose not clear the problem your camera will need a trip to Fuji service to replace the switch or top plate.  I hope it's still under warrantee.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Doug MacMillan Veteran Member • Posts: 3,695
Did you try setting everything to manual?
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
While trying this I've just realised that the dials work properly sometimes... only if I push down on the shutter speed dial very firmly.
Sooooo it's broken. Really frustrating.
nightowlnz
nightowlnz Contributing Member • Posts: 518
Definitely sounds like a hardware issue, like something has slipped between the dial and the electrical contacts or other mechanism which detects the physical position - so they're out of alignment.  Unfortunately sounds like a trip to a service centre will be required.
 nightowlnz's gear list:nightowlnz's gear list
Fujifilm X-T4 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Hardware failure
Also no explanation from my side at the moment other than hardware failure.
I would first do a complete reset and try again.
Having read the post and the replies so far, I wonder - did she exert inappropriate power on the dial, was the camera dropped, or exposed to rain or something else, or is this independent from user failure? How old is the camera, did you buy it new or second hand?
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
