R7 focus stacking in camera
Started 7 months ago | Discussions
jim mij Senior Member • Posts: 1,036
Re: R7 focus stacking in camera
RightMomentRightExposure wrote:
It's good to point out focus stacking only works with inanimate objects.
and "relatively still" live ones(bugs), I often use stacking in small bursts when light / flash permits, other brands are apparently even better
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
drsnoopy Senior Member • Posts: 1,216
Not necessarily - but they do need to be still for maybe half a second.  Butterflies are a good example, handheld stacking with an R7, R5 etc is very fast indeed.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
koenkooi Contributing Member • Posts: 920
And this is where you can point all the sour people saying "REAL photographers don't need 40fps" to. Having the 20fps available for focus stacking larger insects was a game changer for me.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Netspyder New Member • Posts: 1
I find a 20 image stack using the electronic shutter at 30fps works well, and most of the time I am happy with the final composited image and no longer need all the extra jpegs. Is there a setting which automatically discards them after the stacking process is completed?
AnfaengerFotograph New Member • Posts: 15
I would also like to know this.
R2D2 Forum Pro • Posts: 26,531
I don’t use the in-camera stacking feature, but I do use Focus Bracketing for my macros.  It’s transformed the way I shoot macros!  So much easier to achieve the desired focus (focal plane).  Cherry-pick the best frame, or stack later in post!  Easy peasy.
R2
Alastair Norcross
OP Alastair Norcross Veteran Member • Posts: 9,874
I've just checked, and can't find one. What you can do is select one of them to delete, and you get the option to delete the whole sequence. I shoot in RAW, so all the images, except the composited one, are RAWs. I tend to be very reluctant to discard images, though. Just in case I want to redo the stacking in Photoshop, I hang onto them.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Alastair Norcross
A couple of new ones
I'm still loving this feature on the R7. Here are a couple of handheld focus stacks, compositing done in camera. I tweaked the JPEGs in Topaz AI and Lightroom:
By the way, no Christmas tree is complete without a Jean-Luc Picard and a Lucky Cat hanging from its branches.
Alastair
That’s a good point. Thanks.
PenPhotos Junior Member • Posts: 29
I am thinking of switching from a Sony A7III to Canon so I can use the focus stacking feature.
Will the focus stack feature work with strobe lights?
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
no
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
apersson850 Senior Member • Posts: 2,076
You can use it with a standard flash unit, though.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
Alastair Norcross
It doesn't work with flash, because it uses e-shutter. But I use an LCD panel, which gives plenty of light, and can be adjusted for intensity and white balance.
Alastair
Stroboscopic lights hasn't anything to do with the shutter.
Ordinary flash units do, if that's what you are referring to. And there you can have it working with electronic shutters too. It just depends on which camera model you get. My Canon mirrorless does indeed work with flash and electronic shutter in combination.
Anders
This canon manual page says flash is not possible with the r7, see the caution section
also there is no setting to set an interval between shots, to eg let the flash recover
you could perhaps tape over some of the flash pins…
That’s a shame really, other brand cameras do have that feature, and perhaps some other canon bodies too
Jim
Yes, the Canon EOS R3 can use flash with the electronic shutter.
You must have an R3, that is the only Canon body that allows flash with e-shutter.
In the USA, flashguns are often described as “strobes” - incorrectly.
Alastair Norcross
In photography, the term 'strobe' or 'strobe light' refers to a kind of electronic flash. There is nothing 'incorrect' about this usage. Such lights will not work with e-shutter on most Canon cameras.
Exactly. This thread is about focus stacking on the R7, which doesn't work with flash in e-shutter. The only current Canon model that works with flash in e-shutter is the R3.
Again, this thread is about the R7 (it's in the title of the thread).
Alastair
Yes, I know that Americans sometimes have illogical names for things. Like "wireless" implying radio when it just as well could be optical etc.
I checked the meaning of "strobe" and most sources I found said it was a stroboscopic light. Sorry for the confusion.
I've noticed that the headline says R7. So much better to include information about other models too, so those who haven't bought one yet can re-consider if needed.
Anders
