R7 focus stacking in camera
Started 7 months ago | Discussions
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
10
I tried out the R7 in-camera focus stacking, and am very happy with the result. I should say, of course, that I am interested in how my images look to normal people at normal display sizes and normal viewing distances. I'm sure there will be some (one or two at least), who would look at these results and immediately moan about all kinds of objectionable artefacts. This post is not for them. A recent post on this forum served the useful function of bringing two such people to each other's attention. It's nice that they found each other, and they can happily decry to each other the terrible results that other people are actually quite happy with. What I am amazed about with this feature on the R7 is just how easy it is to use, and produce results that I like (as does everyone else who has seen them so far, most of whom are not obsessive pixel peepers). My previous forays into focus stacking were done with the focus bracketing on my M6II on a tripod. I then loaded the files (anywhere from 15 to 30 of them) into Lightroom, and sent them to open as layers in Photoshop. In PS I performed two separate operations on the layers (first aligning, then merging), flattened the layers, and saved the resulting image. With this image from my R7 I set the camera to take 25 images, handheld. It took under a second to take all 25 images, and then around 20 seconds to produce the stacked JPEG. I cropped it a bit, and enhanced a bit in Lightroom. Here's a web-sized version:
As far as I know, the R7 is the first Canon camera to perform the whole stacking procedure in camera (though you can do it manually if you want--the camera also saves all the RAW files). To me, it's like magic.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Canon EOS R7
KevinRA Senior Member • Posts: 1,457
Re: R7 focus stacking in camera
Great stuff - would be interesting to see how it compares to DPP which seems the only option in the R10 and R5 or with Helicon Soft etc...for those with paid software.
Images where part of the object sits a bit in front of something behind it is my challenge at times - even in a simple flower or insect shot like the below which is ~ 12 images - Helicon with some tweaking.   DPP seems not bad but in camera great for speed if it works well!
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
Cameleon
Cameleon Regular Member • Posts: 267
Yes, the built in focus stacking in R7 is amazing. This is one of the reason I bought the EOS R7. My first focus stacking trial was to take a photo of a AAA battery . I took 20 shots using focus stacking and 1 normal shot for comparison.
Conditions
Environment : Indoor subdue light
Camera and lens : EOS R7 / EF 100mm f/2.8L macro
Tripod / Handheld : Handheld
Object : AAA Energizer battery, 44.5mm x 10.5mm
Photos : almost uncropped
Focus Stack : 20 shots, f/4 1/125s ISO 1600
Unstack photo : 1 shot, f/10 1/80s ISO 6400
Files : C-Raw
Workflow : focus stacked by DPP, export to 16 bit TIFF file, denoised by Topaz Denoise AI and convert to jpg file. Copy EXIF data from original file to the focus stacked jpg file using Exifer.
1. Focus stacked photo
20-Focus Stacked photo, f/4 1/125s ISO 1600 handheld
2. Single shot photo
Single shot photo, f/10 1/80s ISO 6400
My conclusions
The focus stacking function is excellent and no post edit for individual files were needed.
High ISO was avoided by using focus stacking, so a better image was obtained.
danferrin Contributing Member • Posts: 730
Looks great to me.  In camera focus stacking is one of the reasons I pre-ordered the R7.  Sure wish it would get here someday soon.
My life is a circle of confusion - photography is my meditation.
See my work at http://www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
Cameleon
Simple and easy as compare to Manual focus stacking
Manual focus stacking :
3 shots, handheld, focus stacked using DPP
need post edit of individual files, very time consuming
Nuksueki New Member • Posts: 3
Conditions
Files : C-Raw
My conclusions
Great review of this function! When i am going to intreduce this function i will link this post!
apersson850 Senior Member • Posts: 2,076
Just so I understand this; does the R7 produce the focus stacked result in the camera too?
I've tried this with my R3, but then I got a bunch of images to run in DPP, to create the focus stacked result. The result was good without any fiddling with any of the base images.
Stacked image.
A single image to compare with.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
DrJohnEvs Regular Member • Posts: 111
Hello - the latest firmware enables the R3 to produce the final image in camera from the series of focus bracketed shots - as per the R7 and R10
The full details are in the Focus Bracketing menu
Cheers
John
 DrJohnEvs's gear list:DrJohnEvs's gear list
Canon EOS 5D Mark IV Canon EOS R3 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +2 more
koenkooi Contributing Member • Posts: 920
apersson850 wrote:
Just so I understand this; does the R7 produce the focus stacked result in the camera too? [...]
It does, if you instruct it to. When 'depth compositing' is enabled, the camera will save the individual pictures (which can be RAW) and generate a JPEG composite. So you can still bring the individual pictures into DPP4/Helicon Focus/Zerene/Photoshop to get higher quality result, but the JPEG is a fast way to see if you need to redo the stack.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Thank you.
You know, I use my camera set to Swedish, not because I don't understand English, but just because you can. But the Swedish translation of Depth compositeis so far fetched that I didn't realize what it meant.
Anders
Bigger Contributing Member • Posts: 640
Thanks for posting this report. I have used focus bracketing on the R5 a lot to make sure I get at least one perfectly focused image. But I have never had the motivation to try focus stacking multiple images in post. Now that I know it works in camera on the R7, I will give it a try.
 Bigger's gear list:Bigger's gear list
Canon EOS 5DS R Canon EOS R5 Canon EOS R7
john80504
john80504 New Member • Posts: 5
I do a lot of focus bracketed work. The biggest problem you all will have depending on your lens is focus breathing. As the focus distance changes, some lens tend to appear to zoom (including primes). Also as the focal point moves further away nearby objects such as tree branches etc. bloom and tend to cover areas you don't want them too. Using Helicon Focus to process the RAW images one can do some correction of this blooming. With the in camera processing I doubt the camera's firmware can make those kind of adjustments.
This is an focus stacked image shot bracketed with Canon R5, Canon 70-200mm lens at 200mm, f/11, 1/125th sec. exposure, ISO 400. It is made up of 878 Focus Bracketed images processed to yield 114 individual Focus Stacked images, 6 rows x 19 columns 30% overlap in portrait orientation.
The original image is: 2.278 Gaga-pixels, 32,282 x 70,569 pixels, 107" x 235" 300 PPI https://abbascreationsphotography.com/GC_Moonrise.htm
 john80504's gear list:john80504's gear list
Canon EOS 5DS R Sony a7R II Canon EOS R5 Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm f/2.8L IS USM +5 more
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Impressive image John and looks a complex job.
May I ask what is a Gaga-pixel? Is it a typo or something I should understand?
Daniele200 New Member • Posts: 6
The R10 also does automatic focus stacking in the camera. There is no need to stack photos in DPP4. The results are remarkable.
 Daniele200's gear list:Daniele200's gear list
Canon EOS R10 Canon EF 50mm F1.8 STM Canon RF 16mm F2.8 STM Canon RF-S 18-45mm Canon RF-S 18-150mm F3.5-6.3 IS STM
drsnoopy Senior Member • Posts: 1,216
The sort of image in the OP will not have much effect of focus breathing, as it is over a relatively (in this case very) short distance, and at a very long focal length (in this case 1600mm effective focal length). But yes it can be a problem in landscape photography with near and far objects. I don’t know whether the in-camera compositing routine in the R7 specifically corrects for this, but all the results I’ve seen from the R7 here and elsewhere, and from Olympus cameras, are so well aligned it seems likely that they do. My own experience is mostly with the R5 for macro, merging in DPP.  For landscape I bracket manually, and merge the images in Affinity, which does a much better job than Photoshop/Lightroom. But it looks much easier to do this in-camera, and as the RAWs are all saved, you can always re-do it on your computer.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
john80504
A gigapixel (Giga-pixel is a spell checkers modification) image is an image made up of a minimum of 1 billion pixels. For example if an image is 10,000 x 100,000 pixels it is 1 gigapixel in size.  Virtually all gigapixel images are created by stitching numerous images together.
Ephemeris
So a typo?
john80504
Ephemeris wrote:
So a typo?
LOL, yes, now I see that it is misspelled.
Oh, so a thousand Million Reasons pixels, then?
https://www.youtube.com/watch?v=hPiWHR16rHI&t
RightMomentRightExposure
RightMomentRightExposure New Member • Posts: 4
It's good to point out focus stacking only works with inanimate objects.
