What 2x extender to canon 70-200 2.8 ef
Started 8 months ago | Discussions
janbanan
janbanan Forum Member • Posts: 70
Hi
what extender 2x should I buy to the canon 70-200 2.8 I  non is.
WindwardHaole Senior Member • Posts: 1,550
Re: What 2x extender to canon 70-200 2.8 ef
You don't indicate what camera you will be using, but I'd suggest Canon's EF 1.4X III instead of the EF 2X III. IQ with either extender will be affected, but less so with the 1.4X III, make up the magnification difference with cropping.
janbanan
OP janbanan Forum Member • Posts: 70
Ok, the Camera Will be a r5
KevinRA Senior Member • Posts: 1,466
OK - so with a R5 would suggest the mark III Canon if you are prepared to pay the price - but the mark II would likely be as good since this is an older EF lens.   Or the DG - NOT DGX - kenko pros should be good on a used copy budget.   I'd avoid DGX's since these mess with the electronics.
Be prepared for 400mm f/5.6 to be soft - it will need to be stopped down to f/8 for sharpness.
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
This year I discovered the EF 2x II is much better than the EF 2x, and that the EF 1.4x III is much better than the EF 1.4x.
I have stopped using the Kenko DG 1.4x as much as possible, since it is inferior to even the EF 1.4x.
All tested with the original 300/2.8 L and 5DSR.
ALL teleconverted lenses should be closed one additional stop to maximize sharpness.
My general experience is that a 2x is worthwhile over 1.4x, but even the L zooms don't take all that well with teleconverters.  Maybe start with the 1.4x and cropping like someone else said.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
Good general rule with most lenses - although I think the very best are absolutely fine wide open with 1.4X TC even on 32 MP APSC.  However the OP’s proposed combo does need stopping down
