problem shooting flash with z9
Started 7 months ago | Discussions
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Today I was able to play with the z9 on a couple of dives.  I'm finding a big issue with the EVF compared to my D850.
With my D850 I see the subject regardless of settings.  Not so with ML.  Consider this.  I'm shooting at iso 64, 1/160th shutter and at least F16, sometimes F29.   My D850 is unperturbed, but my Z9 viewfinder is basically black.  No idea what I'm looking at.
I need some viewfinder setting to counter this.  Im trying Starlight mode.
What are other ML shooters doing for flash at base iso?
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Nikon D850 Nikon Z9
Barmaglot_07 Contributing Member • Posts: 633
Re: problem shooting flash with z9
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
PHXAZCRAIG
OP PHXAZCRAIG Forum Pro • Posts: 19,651
Barmaglot_07 wrote:
Chris Ross has you covered here: https://wetpixel.com/forums/index.php?/topic/69050-macro-on-a-mirrorless-how-to-improve-autofocus-performance/&do=findComment&comment=436925
Many thanks!  I thought I remembered something like that from Thom Hogan's book, but it would take a while to find it.  Assuming I remembered to put a copy on this laptop!
This afternoon I switched all to macro mode, and I tried Starlight Mode in desperation - that seemed to work pretty well.   Might even enhance autofocus.
I have D9 set now (Auto) and I'll see how it works.    It's been by far my biggest problem with the camera.  Z9 seems to be working like a dream, and the Nauticam housing is well done.  But I do have to get used to the controls.
www.cjcphoto.net
PHXAZCRAIG
OK, the viewfinder fix works fine.  But I still have an issue with flash - should have known not to use Auto-ISO with flash.    I get ambient exposures at 25,600 ISO and then the flash goes off an nukes everything.   Back to manual everything.
Slowly getting used to the quirks of the Z9.  Have to say that overall the files are easy to post-process and seem to need less adjustment than the D850, which needed less than the D810.
www.cjcphoto.net
If you want to use auto ISO with flash, the strobes need to be in TTL mode and you need a TTL-capable trigger. If the strobes are manual, then all the camera settings have to be manual as well.
Interceptor121 Veteran Member • Posts: 8,691
Disable the live view simulation and if required use a live view boost mode in case the EVF is too dark
if you change the exposure settings you destroy your image as you are shooting with flash
Also make sure you disable auto iso
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
If you want to get in touch don't send me a PM rather contact me directly at my website/social media
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
