hey, need CC
Started 8 months ago | Discussions
JohnHammock72
JohnHammock72 Regular Member • Posts: 297
hey, need CC
John Crowe
John Crowe Veteran Member • Posts: 3,476
Re: hey, need CC
I don't see anything redeeming in the first and last.
The brick wall is an interesting subject.  Perhaps have someone peering into one of the doors/windows.
The window detail has most potential.  I know it's lying to some, but I would consider cloning out the wires.  With symmetrical subjects I would also try centering them.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
Digirame Forum Pro • Posts: 41,857
Re: hey, need CC
The second and third pictures look OK, with the paint over the bricks. But generally, for improvement you might want to consider more interesting subject matter. Sometimes the subject matter can tell a story, but for something like this it may take a series of photos. Like you may show a wide angle of a building to give someone a general idea of the area. Then maybe a closeup for some detail.
For the last photo, I didn't like the lower part of it. In the first image, the motorcyclist was too far to the left and there was too much "empty" space at the top.
Keep at it. I hope this helped you.
Dunlin Senior Member • Posts: 2,611
no.3 & 4
No.3 & no.4 look good IMO.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
Len Philpot
Len Philpot Contributing Member • Posts: 625
Re: hey, need CC
Very similar reactions to the others who've posted...
#1 - Out of focus and just a snapshot
#2 - This is by far the most interesting one to me. It's really neat the way the mural on the wall plays tricks with your brain. Not sure if I like the shadow or not, but the sign would benefit from somehow being visually separated from the background just a bit. Maybe mask off the sign and play with slight amounts of sharpening, color, brightness, local contrast, etc. It might take several combined, but make it subtle, just enough to 'raise' off the background. If that's possible - Not sure.
#3 - This one has potential. I like the basic elements, but if possible (and it may not have been possible) it would've been nice to find a cleaner view without the stains, wires, etc. I think the relatively stark nature of the elements require by nature a clean presentation. To my eye there's no need for a symmetrical layout, but it still needs to be balanced. But it definitely has potential - Maybe something to revisit?
#4 - There's no clear subject here. Too many elements are competing for attention: sky, blurry foreground, two signs, etc. If the monument is the subject, get closer to it. Also, position your camera so it rises above the "horizon" of background buildings. That will make is stand out better.
Len Philpot
Retirement: 4th best thing to happen to me
https://www.instagram.com/lphilpot01/
https://flic.kr/ps/doiTr
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
